Last Post: kaveebee
0 2 Up Seat Recommendations
Last Post: ReddTigger
0 Bannana Caliper 73 XLCH- no brakes?!?
Last Post: JacksBrother
6 1973 Sporty - Starts, Runs Good, Stops...
0 Dunlop elite 4's?
0 C.O.B.B run west
Last Post: skien
0 Honda Nostalgia
Last Post: felis
0 2016 72
Last Post: 1up
0 New Photo Challenge: Show Us Your Bike Next to a Lighthouse!
0 Thought my clutch went out or tranny, was front pulley
Last Post: leo310
0 Electronic jet kit
Last Post: Jason's Sporty
0 Mikuni Carb vs Easy Kit
0 Primary/transmission synthetic oil
Last Post: XL Ed
Last Post: West Texas Buffalo
0 How old are you?
Last Post: RandyMac
0 Sturgis 2018
Last Post: the cowboy way
0 Plug wire question
Last Post: chris16371
0 Rebuilt solenoid now bike tries to start when I connect batt cable? Wtf?
Last Post: BrokenIron
Last Post: cotton1
Last Post: Roosterman
0 Any K model guys interested in cam regrinding?
0 Who can make a spare key?
Last Post: gravydog
0 Turn signal failure
Last Post: slamtry
0 Killer Instinct Unchained
Last Post: davixlrtt
0 ‘68 XLCH...transmission
0 Solenoid plunger boot super important?
Last Post: Windtheropy
0 Passenger floorboards and backrest questions
Old 17th July 2010
jerseykat1's Avatar
jerseykat1 jerseykat1 is offline
Sportster/Buell Model: 86 sporty 883
jerseykat1 is on a distinguished roadjerseykat1 is on a distinguished road
Default 1986 evo sporty. Is my cam timing set correctly manual is not accurate!
Ok so i was suprised to find out that removing the right side engine cover pulled my timing gears and cams out and cam out of time so i was forced to look at the pdf manual to see how to time everything again. Unfortunately for me the illistrations in the manual are not 100% accurate. all the lines and dimples line up properly except for the intake cam on the forward cylinder. the alignment marks are off about 1/8" and if i move the gear one tooth over it gets worst. So my question to anyone that knows the 86 motor is this normal because i would hate to have to pull this thing apart again. see my picture below.
Thanks so much for your help.
Old 17th July 2010
90sportster's Avatar
90sportster 90sportster is offline
Sportster/Buell Model: 883/Hammer 1250
Sportster/Buell Year: 1990
90sportster has disabled reputation
Looks Good!
Thats exactly how it looked on my '90 before I put in my Andrews cams.
If the #3 cam mark was higher than the #2 cam mark....you would have been off by a tooth.
Old 17th July 2010
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of light
I'd say your good to go. thats where I'd run it.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
