Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Sportster Motorcycle Project
Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
0 Solar battery charging
Last Post: tvon
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Old 17th July 2010
Bobo's Avatar
Bobo Bobo is offline
Sportster/Buell Model #2: X1
Sportster/Buell Year #2: 1999
Bobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura about
Default Cutting 1/4" steel
I have a 1/4" thick peice of weldable steel from Lowes. The piece is 4x12". I will have one cut that will be about 6" long. The rest will be half that.
All I have are a sawzall, jigsaw, and cutoff wheel. I have metal blades for the two saws. Can I do this with these tools? Is one going to work better than the other? I don't have a band saw or a plasma cutter, maybe some day.
Old 17th July 2010
shadecorp's Avatar
shadecorp shadecorp is offline
Sportster/Buell Model: XL883C
Sportster/Buell Year: 04
shadecorp has a spectacular aura aboutshadecorp has a spectacular aura aboutshadecorp has a spectacular aura aboutshadecorp has a spectacular aura aboutshadecorp has a spectacular aura aboutshadecorp has a spectacular aura aboutshadecorp has a spectacular aura aboutshadecorp has a spectacular aura aboutshadecorp has a spectacular aura about
While back bought a cut off disc from Sears.
put it in whats called a contractors saw.
Have cut a lot of rebar.
good luck.
[B]Mustang seat.
ThunderHeader system.
Kurykyn aircleaner.
H.D. engine guards.
H.D. tank bib.
Licks bag.
Arai "Profile" helmet.
Life Member N.R.A.
Life Member C.R.P.A.[/B]
[B]And three years, United States Army. :)
M.P.C.
Cold War Era[/B].
Old 17th July 2010
kg8270 kg8270 is offline
kg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura aboutkg8270 has a spectacular aura about
ive used a jigsaw but take your time
Old 17th July 2010
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
a reciprocating saw will work no problem. have a fresh blade. is this straight cuts? a good jigsaw will also work if not straight cuts. fresh sharp blades is the key
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
Old 17th July 2010
Horse's Avatar
Horse Horse is offline
Sportster/Buell Model #2: XLH 883/1200
Sportster/Buell Year #2: 1995
Other Motorcycle Model: FXDBI
Other Motorcycle Year: 06
Horse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to behold
I prefer using a cutoff wheel on my high speed grinder if I don't have a bandsaw available. I have trouble with getting straight cuts with hand held saws.
R.I.P. Brother
Mocha Mafioso
Old 17th July 2010
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant future
If you have a cut off saw or a miter saw, you can buy a carborundum blade (looks like a brown fiberglass wheel. They come in 8, 10 and 12 inch diameters. Buy the one that fits your saw.
Use it ouside. It makes lots of spots and leaves metal dust all over the place.
Cut slow. It will make a straight acurate cut with out all the elbow grease need with a jig saw.
If I had to use a sawzall or jig saw (and I have in the past) I would clamp 2 guides to the plate to prevent the saw from drifting.
Old 17th July 2010
ozark ozark is offline
Senior Bike Builder
Other Motorcycle Model: 02 SV gone but not forgot
ozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to behold
Hi,
I'm not a steel fabricator by any stretch of the imagination. Usually the first tool I reach for is my side grinder. If I have to make a pretty long straight cut I use a metal blade in my circular saw. I can get a pretty smooth cut with an edge guide.
If I want it done really clean and accurate I take it to the people who make my saddlebag brackets and seat backs. (It's nice to know a guy with a plasma cutter
Ozark
Old 18th July 2010
Bobo's Avatar
Thanks everyone. I have fresh new blades for the jig. Going to give that a go first just cause I want to see how it does as I have a few slight non-straight lines. Cutoff is my back up for everything.
Old 18th July 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I would use the sawzall and dress it up with an angle grinder.
Old 18th July 2010
Horse's Avatar
I was at home depot today and noticed that they sell a metal blade for standard 7 1/4" handheld wood saw, lol. I bet its LOUD
