Last Post: blindfredy
0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: spoon
0 first harley- help!!
Last Post: Hellbent_4
Last Post: cantolina
Last Post: mac93
0 oil cooler or not?
Last Post: Jason's Sporty
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Intro from New England
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
0 Head gaskets.
Last Post: sevenyears of famine
Last Post: friday
Last Post: guitarfish
0 oil pouring out on right side
0 Sunday 20th May 2018: Hope Cove
0 new oil lines
Last Post: 69sscamaro
Old 22nd June 2005
nzsailor nzsailor is offline
nzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the roughnzsailor is a jewel in the rough
Default Please help...brake fluid
This is my second post on this subject. I’ve got a 79 XLS. Rebuilt the front master. I asked what kind of brake fluid to put in and was told that only DOT 3 was in use in 79. And you’ve all got real honest looking faces so I believe that. Also was told the cover should tell what kind of fluid to use so I looked and it said DOT 5. I assume it's not OEM even though the kit parts matched what I took out. My dilemma: How do I determine what kind of fluid is in there now. I would expect that my rebuild kit and possibly the slaves were made for DOT 3. Will DOT 5 rot the rubber? The bleed fittings are at the top of the calliper cylinders. How do I flush all the fluid out? I’ve got a bottle of something called DOT 5.1 that says it’s compatible with DOT 4. Anybody had any experience?
Any superior knowledge greatly appreciated.
Thanks
Sailor
Old 22nd June 2005
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
You run whatever ya want ....PROVIDED ya flush it properly..
dot 3 , 4 and 5.1 are the same family and are compatible the higher the number the higher the boiling point
dot 5 is silicon fluid and wont attack your paint like the others and is compatible with nothing.........
Use a fresh bottle of a different coloured fluid to what's in there and remove the brake line from the caliper and drain the fluid out......
then reconnect and fill the master cyl and keep bleeding till well past the fresh stuff comes out of the caliper
Old 22nd June 2005
GoatDog's Avatar
GoatDog GoatDog is offline
Sportster/Buell Model: 1200 Roadster
GoatDog is an unknown quantity at this point
Had an 80 XLS Roadster that used Dot 3. Had it since new to 1991. I cannot be certain that a 79 is the same, but my 80 was definitely Dot 3.
Jim "Goatdog" Miller
2004 XL1200R
Old 23rd June 2005
From the FM for 1979 to 1985 XL/XR models: "DOT 5"
From Clymer 1959 to 1985: "DOT 3 for models before Sept 1976 DOT 5 for later models"
Old 23rd June 2005
79iron's Avatar
79iron 79iron is offline
Sportster/Buell Model: XLS Roadster
Sportster/Buell Year: 1979
79iron has disabled reputation
yep, my 79 is definately dot 5
Old 24th June 2005
jcrow jcrow is offline
jcrow has disabled reputation
Dot 3 is more of a solvent based and moisture mixes with it. It also has a lower boiling point than 4 and or 5. 4 is a sort of blended fluid that has properties that resist collecting and mixing with moisture. 5 is straight silicone than they claim won't mix with moisture. Reverse bleed from the bottom up using a syringe and tubing, or if you have patience, take the lines apart and flush them out. There are web sites that explain the brake fluid properties fully. Dot 4 or 5 should work fine. I feel the main concerns are moisture collecting over time and causing the system to corrode and fail and boiling point due to the heat in the calipers. If you are a worry type, flush and inspect every spring
