0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 25th July 2010
mybimmmer mybimmmer is offline
Sportster/Buell Year: 1973
mybimmmer is an unknown quantity at this point
Exclamation Need help with 1973 XLH
Just purchased my first Harley last Thursday. I'd like to know as much as I can about the Harley (1973 XLH) I purchased and will post pictures below. I can't tell what's been done to it but it looks longer than the normal XLH's that I look at. Any help figuring out what's been done to it from the pictures would be greatly appreciated!!!! Thanks a ton!
Old 25th July 2010
Old 25th July 2010
Old 25th July 2010
boilermaker's Avatar
boilermaker boilermaker is offline
Sportster/Buell Model: 81 sporty
boilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really nice
Well for starters its been hard tailed hence the longer then normal
sesenta y ocho
Old 25th July 2010
Thanks for the quick reply. I am very new to Harley's and I'm not real familiar with being hard-tailed. Was it originally a softtail?
Old 25th July 2010
72Iron's Avatar
72Iron 72Iron is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: Harley-Davidson
Other Motorcycle Model: FLHTCU (Geezer Glide)
72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice
Originally it had a swing arm with shocks. Hard-tailed means the PO put a rigid rear section on it, be it bolt or weld on. It can increase the stretch quite a bit. Looks goo though.
I gave up smoking, drinking and sex.
It was the worst fifteen minutes of my life.
RIP: Eli
Old 25th July 2010
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Welcome to the XLForum.
My first Harley was a brand new 1973 XLCH 37 years ago.
Old 25th July 2010
I did a little research on it. I want to turn it into a bobber. Do the front forks look original to you? How hard is it to convert the rear brake into a disk brake? I think I will remove the front brake entirely. It supposedly has a S&S stroker kit on it ...anyway for me to verifity that? It's really really loud though and I love the sound. Thanks a ton for the help!
Old 25th July 2010
Horse's Avatar
Horse Horse is offline
Sportster/Buell Model #2: XLH 883/1200
Sportster/Buell Year #2: 1995
Other Motorcycle Model: FXDBI
Other Motorcycle Year: 06
Horse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to behold
cant tell for sure but it looks like it might have stroker plates under the jugs. Hard to tell from the pic. It's a hard tail so making it a bobber is easy from there. some welding and fab work is needed to mount a rear disc, but it isn't impossible.
R.I.P. Brother
Mocha Mafioso
Old 25th July 2010
Original frt forks you would be asking for trouble removing frt brake rear drum where marginal at best when new not something to rely on as only means of stopping.some finaggling may get a rear disc on there never know.remove timing plug and roll engine over and look for marks on crank that might tell you but I doubt its a stroker
