28th July 2010
Posts: 336 Sportster/Buell Model: M2 Cyclone Sportster/Buell Year: 2001
Thoughts on the Evo Sportster
I'm really a big twin guy, but had an Ironhead for many years and currently have a tuber Buell.
So I'm just wondering..................
When the Twin cam BT motor came out all I read was that one of the main design objectives was to reduce mechanical noise so the exhaust would not have to be so restrictive. Thus, chain driven cams were quieter than a single gear driven cam.
I figured that some sort of redesign on the Sportster would be coming soon.
I mean, FOUR gear driven cams has to be noisier than one, right?
But now the TC has been out for over ten years, and the Evo Sportster soldiers on basically unchanged. I expected the rubber mounted Sportster of 2004 to have been the time to introduce engine changes (along with a 6-speed trans), but it didn't happen. There have been substantial changes to the XL motor, but it has retained its 4 gear driven cams.
While I don't really feel either the Sporty or BT need 6 gears, if the BT gets a 6 speed, it only makes sense to eventually give the Sporty 6 gears at some point. Of course, the BT 5-speed came out in 1980, the Sporty didn't get its 5th until 1990.
Anyone else find these things curious?
Shupe
1997 ElectraGlide Classic (bought new)
1976 Shovelhead
2001 Buell Cyclone
28th July 2010
Posts: 9,051 Sportster/Buell Model: FXRS-SP Sportster/Buell Year: 86 Other Motorcycle Model: wla flathead45 Other Motorcycle Year: 1945
thank god they don't go chain...
chains wear out and need to be replaced. gears rarely wear out.
why do you think that they make gear drive systems for chevy V8's
chain drives are cheaper to mass produce
"lord of the Night Lite"
thank god for darwin ;)
28th July 2010
Posts: 2,982 Sportster/Buell Model: XL1200c Sportster/Buell Year: 1996 Sportster/Buell Model #2: XL1200, 2003 Other Motorcycle Model: Suzuki T250 Hustler Other Motorcycle Year: 1971
shupe,Nope. Like it or not the Sporty is HDs price leader, Good value for the cost and a competitive performer in its class. IMHO the 6 Spd is a marketing tool, not an engineering improvement. With the Torque of a V-Twin, 5 Spds are more than enough, I would like to see a Hotter 1st gear in the 1200s 5 Spd box instead of a 6. The 4 cam design is an Iconic part of a Sporty, plenty of other choices on the market, all trying to be a Sporty!!
28th July 2010
Posts: 2,524 Sportster/Buell Model #2: XLH 883/1200 Sportster/Buell Year #2: 1995 Other Motorcycle Model: FXDBI Other Motorcycle Year: 06
One of the first mods I made on my dyna was gear drive on the cams. Changing to chain on a sporty would be a mistake I doubt they'll make.
R.I.P. Brother
Mocha Mafioso
28th July 2010
Posts: 7,435 Sportster/Buell Model: Sportster 1200C Sportster/Buell Year: 06
Same reason they left the Nosecone that does nothing I think, Because the 4 gear driven cams and the noise that goes with them have always been "Sportster"...
The 04 Design changes were inline with the market and keeping the sporty A Sporty....
28th July 2010
Posts: 50 Sportster/Buell Model: Sportster 1200C Sportster/Buell Year: 2004
I have a '04 1200C and find I rarely use the 5th gear. Great torque and minimal shifting now. I don't use 5th till 72+mph and it purrs along at 85mph.
How would a 6th gear improve the bike?
28th July 2010
Posts: 5,848 Sportster/Buell Model: Sportster 883L Sportster/Buell Year: 2006 Other Motorcycle Model: Honda CB350 Cafe Style Other Motorcycle Year: 1970
I think that HD is planning to make changes to the Sportster engine and the others when they need to comply with EPA regs that require motorcycles to be watercooled. It's going to happen. The question is when. It's a money issue for HD at this time. That kind of R&D is not cheap.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
29th July 2010
Posts: 517 Sportster/Buell Model: 883 Custom Sportster/Buell Year: 2002
6th would be the same as 5th is now with a closer ratio gearset
29th July 2010
Posts: 3,100 Sportster/Buell Model: xl 883c<1212 Sportster/Buell Year: 2005 Other Motorcycle Model: RoadKing Classic Other Motorcycle Year: 2010
that will be a sad day. I am glad I got one of the last carbed models. gonna keep this one for a while.
I find it hard to believe that "everybody" was Kung Fu fighting.
29th July 2010
Posts: 1,444 Sportster/Buell Model: White Hot Denim XR1200X Sportster/Buell Year: 2011
If they have to make a sportster quieter they have other things to worry about than the gear driven cams.
