0 Stock vs. Modified
Last Post: blindfredy
0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
Old 30th September 2007
Sp0rtster Sp0rtster is offline
Sportster/Buell Model: xl883
Sp0rtster is an unknown quantity at this point
Default Speedometer Wiring?
Ok, for those of us not electrically inclined...
Just changed my mini speedometer to a larger one with the bob style tank. Figured out the cable part, even figured out the hot and ground wires for the light in the speedo housing, but WTF does the green wire do? There are three friggin wires on the harness coming from the bike and there doesn't appear to be any place on the back of the speedometer to attach it to?
Ideas?
miller's Avatar
miller miller is offline
Other Motorcycle Model: Honda Trail 70
Other Motorcycle Year: 1970
miller has disabled reputation
If it's a green & white wire, my diagram shows it running to the Turn Signal Canceller Module. If it's an aftermarket speedo, it doesn't have the self-cancelling stuff. So, brace yourself, you'll have to remember to turn your signals off
On the back of the Harley Speedo is a green wire. That is a turn signal cancellor? If so, since I don't have one on the aftermarket speedo, problem solved. thx.
miller's Avatar
I'm looking at a diagram for 91-94 models, and there are 3 wires coming off the speedo: orange/hot, black/ground, & green & white/turn signal cancell. So yeah, that must be it. Good luck.
Coolness, thanks bro.
Old 30th March 2008
chef52678 chef52678 is offline
Sportster/Buell Model: XL883C
chef52678 is an unknown quantity at this point
I am not sure if I am in the right forum. I am adding a tachometer to my 2007 Sportster 833. The only connection I need to make is the pink wire which is the lead that connects to the speedometer however I am not sure which position it goes in. There are three empty spaces in the connector but I can't remove the protective caps that are on the connector. Can anyone help me? Anyone have a diagram? Thanks!
Old 30th March 2008
jwb's Avatar
jwb jwb is offline
Sportster/Buell Model: XLH883 standard
jwb is on a distinguished roadjwb is on a distinguished roadjwb is on a distinguished roadjwb is on a distinguished road
The forum is OK but this is a speedometer thread.
Try a search on "883 custom tach" or if that doesn't work start a new thread of the same name.
By the way, welcome from OHIO.
John
2002 XLH883 Standard, V&H straight shots/dynojet/K&N hi-flo, Tach Kit,
Full front fender, premium leather saddlebags, detachable compact windshield and some chrome.
Old 30th March 2008
Thanks for the welcome John (and for the search tip). You're bike looks awesome.
