0 Tap extention?
Last Post: T. Clark
0 Tank swap
Last Post: Grymy
0 How do you upshift?
0 Lowboy frame conversion
10 Anyone else noticed this? (Horn Closes Choke)
0 Oil Hose replacement help.
0 Spokes or Mags
0 New From CA
Last Post: jcro61
Last Post: MXHD55U
Last Post: Crosshairs
Old 5th August 2010
jonnybravo jonnybravo is offline
Banned
Sportster/Buell Model: Ironhead Chopper
Sportster/Buell Year: 84
Other Motorcycle Model: Kaw Z1 900
Other Motorcycle Year: 1973
jonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura about
Default sprocket shaft seal
got a leak, I have looked and looked and cant find the instructions in my FSM i have an E84 ... clues ????
Old 5th August 2010
47Harley 47Harley is offline
47Harley is an unknown quantity at this point
Instructions for what?
Old 5th August 2010
Sprocket shaft seal installation instructions are on bottom left and top right of page 6-25, in 99484-85. Some additional info on bottom right of page 6-18. Schematic diagram is on 6-17.
Note that you install the sprocket twice, once to position the seal/retainer; then a second time to finalize the installation. This is important.
Old 5th August 2010
Banned
thanx my version pdf is missing one diagram but the others are enough, a terminology error on my part really ..
Old 5th August 2010
I have a cut down sprocket that I install to center the seal and allow me to tighten the screws with the sprocket installed.
Old 6th August 2010
Banned
hey mick got the part number for that seal ??? didnt see one on J&P site but then I'm not sure, I'm getting conflicting info on my searches
Old 6th August 2010
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
You can make a tool if you have a lathe available, instead of installing sprocket twice, you may need to grind bolt holes in reatainer slightly to center corectly.
Old 6th August 2010
Banned
correct me if I'm wrong but the FSM says i gotta take out the transmission???
Old 6th August 2010
chevelle's Avatar
Are you talking Engine sprocket or Transmission final drive sprocket? Either way case does not need to be split!
Old 6th August 2010
I am talking about the front sprocket for the rear chain. This is known as the transmission sprocket. The seal is called the mainshaft oil seal. The transmission does not need to come out to remove/install this sprocket or the seal/retainer.
The seal is part number 35151-52A; the retainer is 35254-52; together they are part number 35150-52. It is common practice to replace both together as there is then less chance of it leaking.
