0 Ei
0 24633-77 Breather assembly
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
0 2016 48 Hesitating
Last Post: 201648Rider
Last Post: Larry May
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
0 New England 2018
Old 10th August 2010
Kirk the Jerk Kirk the Jerk is offline
Senior Bike Builder
Sportster/Buell Model: None
Sportster/Buell Year: None
Kirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to all
Default Gas Cap Leak...
Topped off yesterday before a ride, and had gas going down the spine of the tank for a bit, wiped it up & tightened the cap, and it was fine. So I just figured it was a loose cap.
Filled it up just a bit ago, making sure the cap was tight and straight, and it did the same thing on the way home...
Only thing I can think of is the heat as of late (100* plus days lately) is causing the gas to expand a bit after topping it off and capping the tank.
Thoughts?
JoeFriday77's Avatar
JoeFriday77 JoeFriday77 is offline
JoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really niceJoeFriday77 is just really nice
You should have an overflow tube that comes out of the back of the tank. Are you seeing anything come from there? I would think you should see it there before coming out the top.
'05 Electra Glide Classic Peace Officer Edition
xtremer-pxl's Avatar
xtremer-pxl xtremer-pxl is offline
Sportster/Buell Model: XL883C converted to 1200
Other Motorcycle Model: FLHX Street Glide
xtremer-pxl will become famous soon enoughxtremer-pxl will become famous soon enoughxtremer-pxl will become famous soon enoughxtremer-pxl will become famous soon enoughxtremer-pxl will become famous soon enoughxtremer-pxl will become famous soon enough
mine started doing that..but I had dropped my gas cap. I didn't see anything wrong with it. I got a new one off ebay for $15. and it no longer leaks.
2012 Street Glide & 2001 XLC
Senior Bike Builder
Yeah, checked that already, nothing I can see...
Hmm... I haven't dropped mine or anything. Maybe it's worth the $15 bucks to replace it...
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
You can replace the gas cap o-ring for less than $2.00.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Senior Bike Builder
Oh, I didn't know there was an o-ring... that's probably the ticket...
grancuda's Avatar
grancuda grancuda is offline
grancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to beholdgrancuda is a splendid one to behold
Mine stock cap was leaking on my Iron and I was just tighning it by turning it till it clicked. I have started putting a little pressure downward and it goes about 1/2 a turn tighter and it has not leaked since.
egadd's Avatar
egadd egadd is offline
Location: SW PA, between Pittsburgh PA and Morgantown WV
Sportster/Buell Model: 883 Hugger/1200 conv
Other Motorcycle Model: H-D Nightrod
Other Motorcycle Year: 2007
egadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really nice
Originally Posted by grancuda View Post
mine stock cap was leaking on my iron and i was just tighning it by turning it till it clicked. I have started putting a little pressure downward and it goes about 1/2 a turn tighter and it has not leaked since.
x2
skeith5's Avatar
skeith5 skeith5 is offline
Sportster/Buell Model #2: IRONHEAD
skeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of lightskeith5 is a glorious beacon of light
Yep..make sure your fuel cap clicks a couple times when you put it on. They are designed to click when tight. Same thing goes with modern cars.
Scott
kNiGHt FaLL's Avatar
kNiGHt FaLL kNiGHt FaLL is offline
kNiGHt FaLL is an unknown quantity at this point
i have two friends.... one with a bob and the other has a rocker and they both do it. Mine no, but i have a different cap on it now.
