0 More of a reintroduction
Last Post: k9unitb
Last Post: 45Brit
0 crack in head
Last Post: slamtry
0 Clutch Spring plate poll
Last Post: NZstu
Last Post: 45Brit
Last Post: kaveebee
0 Cylinder Piston kits
0 Bars on C Riser?
Last Post: mattjs666
0 1967 XLCH stroker project
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
0 Fact or Fiction - HP Claims
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Last Post: kaveebee
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The White Bike is the Right Bike Thread.
Last Post: if6was9
Last Post: Slidesquad24
Old 4th October 2007
Rudy2 Rudy2 is offline
Sportster/Buell Year: 1982
Sportster/Buell Model #2: Triumph T140
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Norton Commando
Other Motorcycle Year: 1972
Rudy2 is an unknown quantity at this point
Default Trans rebuild questions
Well, I have bought replacements for my water damaged primary drive and transmission and will be reassembling my "bargain" '82 soon. I have a background in this sort of work and a factory manual so I am almost ready to go. One thing that is different about this trans is the oversize roller thing. This is pretty unusual but apparently there are several roller sizes to choose from for setting up the output bearing. How do I know what size roller to use? I must need to know diameters of the shaft bearing surface and outer race I.D. as well as clearances. Anyone know about this?
Randy
Old 5th October 2007
Sportster/Buell Year: 1972
You are right on track Randy, you need the shaft O.D. and race I.D to size the rollers. Oversize rollers are manufactured to achieve correct fit in worn races. If you can see obvious wear. scoring, pits, etc. the race must be lapped to remove these indications. Believe there is a special lap sold by Jims Machining for this, probably not cheap. Once lapped, the roller size is determined based on the measurements and clearance required. Strongly suggest you refer to the factory manual for this procedure.
