0 1974 Ironhead
0 24633-77 Breather assembly
Last Post: Fridge
Last Post: GeoK
Last Post: GeoK
0 ‘68 XLCH...transmission
0 New from Utah
Last Post: GeoK
Last Post: hexnut
Last Post: Jheitt
Last Post: Jheitt
0 primary chain temp.
Last Post: shovithead
Last Post: cazz1000
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: Crash7557
Old 22nd August 2010
JBierschwale JBierschwale is offline
Sportster/Buell Model: XL
JBierschwale is an unknown quantity at this point
Default 1977 ironhead not firing on front cylinder
I have a 1977 ironhead chopper that will not fire one the front cylinder all the time. We've replaced plugs, wires, coil with known good parts. Checked for vacuum leak at the intake, new rubber there. Runs all the time on the rear cylinder, but will only fire on the front cylinder when you rev the engine. Adjusted the valves with no change. Points have been adjusted several times. Has new thicker copper head gaskets. Points are advanced almost as far as they will go. Any ideas? I have to have this bike running today. Thanks, guys!
72Iron's Avatar
72Iron 72Iron is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: Harley-Davidson
Other Motorcycle Model: FLHTCU (Geezer Glide)
72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice
Condenser?
I gave up smoking, drinking and sex.
It was the worst fifteen minutes of my life.
RIP: Eli
superwarden's Avatar
superwarden superwarden is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLC
Other Motorcycle Model: FXSTD
superwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of light
Compression test?
Any date that is not on your tombstone is considered a lucky day.
ericfreeman's Avatar
ericfreeman ericfreeman is online now
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
JB
You'll likely get more replies if you post your issues on the Ironhead Forum directly. Lots of us tend to skip over the other sub-forums and stay where the posts are more relevant.
Eric
Check your points gap on both of the lobes of the timing cam. These cams are notorious for being off and you may find a gap of say .018" on one side and .025" on the other. Some of us have had success by loosening the cam lockscrew slightly and shifting the cam over to the tighter side, thereby averaging out the 2 gap readings. May take some fiddling to get the two point gaps within .004" of each other, the factory spec.
Eric
wedge's Avatar
wedge wedge is offline
What's the compression? Is the front backfiring through the carb when it trys to run?
Compression is good on both cylinders.
Just checked points gaps - .018 on both lobes.
Old 23rd August 2010
Compression is right at 90 on both cylinders. My compression gauge could be wrong, though. We just rebuilt this engine. It has spacers under each cylinder at the base, and thicker copper head gaskets (.030 or better). It has pop up pistons (not sure if they all do). It seems like it's hard to crank, as it kind of stalls while using the electric starter while trying to start it, especially after you twist the throttle to give it a shot of gas. As soon as you twist the throttle, it pauses while cranking, like it's trying to fire the charge before TDC. It has an S&S Super E. Correct o-ring intake with the bands and o-rings, and updated intake clamps. It will sneeze through the carb occasionally, especially if you blip the throttle. Not sure which cylinder that is coming from. It backfires pretty bad through the front pipe (has drag pipes) about every 10th revolution. It's not firing all the time on the front cylinder, so it pumps intake charge through the cylinder into the pipe and then ignites it when it does fire. We turned the points cam 180 out and couldn't get it to start, even adjusting the points from one end to the other. The only way it will run is if the points are adjusted all the way counter clockwise while looking at the points side of the bike. We did not do anything with the cams when we had the motor apart to do a top end. Only base gaskets up.
Forgot to mention - we had to replace the front head with a used one. The exhaust flange broke off of the original head. I did replace it with the correct numbered head. The seats looked perfect, so I installed the valves/springs/keepers in the replacement head. We did bore the cylinders. Replaced rings, pistons, all gaskets.
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
Give this a try on a cold start up pull front plug wire to where just the boot is holding it on,it isn't snapped in the metal the snap on plug wire is sitting on top of plug.Start bike as your riding down road and it's warmed up pretty good reach down and snap frn plug wire back down.Hope this wks for you I had a rear cyl this wkd on as the rear cyl heated up push plug wire down it didn't miss a lick but everytime on a cold start I had to do this as you say everything ckd good.By the way if your plug wires are good and you push from top you won't get shocked.
Murphy's Law :vvet:
