0 Solar battery charging
Last Post: Ranchero50
0 Lowboy frame conversion
Last Post: chevelle
Last Post: David L.
Last Post: Naplesron
Last Post: Grumpy-Biker
0 Primary Oil INSANITY!
Last Post: randy3934
0 Left Side Exhaust?
Last Post: maltesefalcon
Last Post: blindfredy
Old 3rd September 2010
lonerider1985's Avatar
lonerider1985 lonerider1985 is offline
Sportster/Buell Model: sportster xlx61
Sportster/Buell Year: 1985
lonerider1985 has disabled reputation
Default transmission oil
Have anyone herd of using 60 wt oil in the transmission ,?this was told to a friend that has a 1979 ih he was told to because the bike is so old ..and if this is true can this work for newer ih s
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
older IH used same oil in trans as in motor because the two could mix.Don't think 79 had foo foo valve but not sure.
Murphy's Law :vvet:
Ripp's Avatar
Ripp Ripp is offline
Ripp will become famous soon enoughRipp will become famous soon enoughRipp will become famous soon enoughRipp will become famous soon enoughRipp will become famous soon enoughRipp will become famous soon enough
I concur..I use 50 weight in both the motor and transmission on my 75.
1975 Sportster XL
[FONT="Century Gothic"]I Fish therefore I Am[/FONT]
The foofoo valve and the valve that causes some oil mix are two different ones. The foofoo if in the gearcase cover, the other is in the primary. 77 was first year for a foofoo, previous years had a timed breather setup. It is external for 77 & 78, then internal for 79-on.
There have been a few comments here recently that 60w is too heavy for the clutch, but that it is used in the engine in desert climates. Otherwise 50w in both.
piniongear's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
Ironheads older than 1976 have a transfer valve which allows engine oil and transmission to mix to a small extent.
For this reason all oils should be the same.
That oil is 60wt.
In 1977 the transfer valve was eliminated and the transmission venting system was changed.
New oil recommendations were issued for the 1977 and newer models, so follow those recommendations for these machines.
Under no circumstances use 60wt oil in a 1979 transmission.
pg
Ivan RoachCoach's Avatar
Banned
Default In older IHs, plug/weld the valve shut & run Formula Plus...
...trans/primary fluid from H-D instead of motor oil.
You'll notice a HUGE difference in ease of engagement and a more positive feel at the lever.
Motor oil in the primary was adequate back when there was nothing else.
Between the Formula Plus, a Tamer II, and Machinist Mike's HydroClutch kit I now have a true two-finger clutch on my '74 that's pure butter.
It's called PROGRESS.
... 60w is too heavy for the clutch ...
Originally Posted by piniongear View Post
That oil is 60wt ...
Originally Posted by Ivan RoachCoach View Post
...trans/primary fluid from H-D ...
... and do not ever, ever expect all of us to agree. Read all the opinions, get all the tech info you can, then make your own decision.
piniongear's Avatar
And just for the record, and to either help you make your decision or perhaps confuse you more.......
I would never remove or block the transfer valve in a 1974 model (the OP is talking about a 1979 or newer model?) nor would I ever use anything but engine oil in a 1974 myself.
On a 1979 or newer I might use ATF but a better choice in my view is to use Harley Transmission lube.
pg
Derek43WLC's Avatar
Derek43WLC Derek43WLC is offline
Sportster/Buell Model: WLC
Sportster/Buell Year: 1943
Sportster/Buell Model #2: XLX
Sportster/Buell Year #2: 1983
Other Motorcycle Model: Harley Davidson FLH
Other Motorcycle Year: 1976
Derek43WLC will become famous soon enoughDerek43WLC will become famous soon enoughDerek43WLC will become famous soon enoughDerek43WLC will become famous soon enoughDerek43WLC will become famous soon enoughDerek43WLC will become famous soon enoughDerek43WLC will become famous soon enough
I tend to think "what worked then, should work now".
Stick to what the old ID's are use to
Sure, time change, advancements in lubes and oils... but, sometimes adding any modern lubes/oils may make them run better but may also have some unwanted side-affects later on.
IMO
Dee
chevelle's Avatar
chevelle chevelle is online now
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
pg
Why do you mention a 1974? What is special about a 1974?
