0 Diagnostic help
Last Post: cotton1
0 headight housing
Last Post: Len PA
Last Post: MatHormell
0 Hope Cove, 20th May 2018
Last Post: Gamble Gold
0 A Day in the Life...
Last Post: cotton1
Last Post: cotton1
Last Post: 83XLX
Last Post: lugster
0 The country store
Last Post: lugster
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
Old 10th September 2010
Big_e78 Big_e78 is offline
Sportster/Buell Year: 1968
Big_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enough
Default Swingarm Bearings
I can't get the bearing lock nut nut (as it's called in the manual) off of my swingarm. I can turn the pin wrench about 180 degrees, then it stops. Does the whole thing unscrew like a bolt or does it just turn one direction (like it's unlocking) then I knock it out? I don't want to go pressing it out and screw up some threads. Here are the actual instructions in the manual regarding the nut "With a punch turn out bearing lock nut and remove pivot bolt nut". Thanks.
RcRacer's Avatar
RcRacer RcRacer is offline
Sportster/Buell Year: 1981
RcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura about
I had the same problem on my '81 when I rebuilt it. The shop manual recommends staking the edge of the lock nut after it is installed. This peens the threads and doesn't allow for it to be removed. There are several approaches. You can grind or drill the peens so that the disrupted part of the thread is removed or you can do what I did. I cut a pie shaped sections out of the locking ring with a dremel tool and cut off wheel. I then took it out in pieces. The trick is not to damage the swing arm threads. I "chased" ( cleaned up ) the threads with a dremel tool and a small cutoff wheel ( very carefully and with a lot of patience ) and installed a new lock nut ring from JP cycles. I bought the entire rebuild kit that included the bearings etc.
Good call. Never thought about cutting it like that... Hopefully I can just buy the nut.
