0 Intake manifold gasket fitment
Last Post: BlackBettyXLC
0 Hillbilly Hot Dogs
Last Post: BSA Bob
0 Anyone know how to stop the ads from coming in from the right side of this page?
4 Occasionally running troubles
Last Post: jcro61
0 My last real nagging problem
Last Post: Keep it running
0 Oil Pump upgrade
Last Post: hotrodbiker
Last Post: wongjohnson
Last Post: Ridneck1986
0 Xl/Buell drag bike parts
0 The country store
Last Post: lugster
0 XR1000 carbs Dellorto
0 Lost compression?
Last Post: semjpm
0 TC88A and Raptor shift light
Last Post: AnaChris
0 1995 Odometer Acting Strange
Last Post: JackFrost71
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: NZstu
0 2014 Sportster 48 $5500
Last Post: ChaseN
0 Carb issues
0 Am I missing a front wheel spacer?
Last Post: jharback
0 Oil On Underside Of gas Tank
0 Stuck in fist after a spill
Last Post: amfxlh
0 Removing powder coat?
0 Spokes or Mags
prbetts (71), 1988XL (67), jbcant (66), gearman (63), rejeanprimeau, Hdrider8831200 (57), AOW (50), adair727, Mechano (46), 64physhy, Buckshot (44)
battery, box, hardware, mount
Old 23rd September 2010
pdamedic's Avatar
pdamedic pdamedic is offline
Sportster/Buell Model: 1000 XLH
Sportster/Buell Year: 1976
Sportster/Buell Model #2: 1000 XLH Project
Sportster/Buell Year #2: 1979
Other Motorcycle Year: 2008
pdamedic is an unknown quantity at this point
Default Mounting Battery box on 1976
I am working off a few boxes of parts and trying to see just how the battery box mounts. It looks like it just sits on top of the starter with one mounting point on the rubber part behind the rear cylinder. Questions;
Is there anything that sits under the box?
I see the oil tank mounts on one side so that must be the anchor point on that side. What about the other side, where does it mount to? Should there be rubber washers or some other hardware? I have looked for a photo but no luck yet.
1976 Sportster, 1979 - Sportster, 1974 - Bike in a box project.
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
The battery box has four bolts that mount it to the oil tank. The oil tank mounts to the right side of the frame with one of those rubber grommet things and then mounts down low to the bracket on top of the transmission. Also, the battery box mounts to the left side of the frame with another rubber grommet. You need to get some manuals. It gets a whole lot harder than this.
pdamedic's Avatar
Thanks, that does help. I do have a manual it covers several years but I could not find anything that detailed that part of the bike. What do you use?
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
You need to get a factory parts book. They show exploded diagrams of how every piece on the bike fits together.
Or try looking at the parts diagrams on bikebandit.com
pdamedic's Avatar
Thanks man, biker bandit does some some of it, but a parts manual sounds like the way to go if it shows the details.
Here are some 1978 pics ...
#1 - battery +ve cable in not correct; it runs inside the battery box; the purple wire is supposed to be green, at last 12 gauge.
Old 24th September 2010
pdamedic's Avatar
Perfect...thanks Mick! Now to dig for those rubber fasteners....should be here somewhere.
