0 Ironheads
Last Post: Island Dude
0 2016 Sportster Rear Wheel Removal w/ABS Brakes
0 Slip on muffler
Last Post: Tucsonmax1
0 Decman's Birtday
0 New member in MD
Last Post: RKN
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: blk80bike
0 acc pump
Last Post: lwh1950
0 What's your helmet?
Last Post: 83XLX
0 Rear tire
Last Post: 83XLX
Old 24th September 2010
Smokin Sam's Avatar
Smokin Sam Smokin Sam is offline
Sportster/Buell Model: 1460 Sportster
Sportster/Buell Year: 1991
Smokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura aboutSmokin Sam has a spectacular aura about
Default Oil light flickers 1989
I am having some trouble with an oil light flickering and it stays on some times at idle with a hot motor. It always goes off above 1000 rpm or if you even touch the throttle.
I have checked for flow to the pump and have good return to the tank. There is a new low pressure switch. All the lines are clear. I have inspected the spring and check ball in the filter housing. We even replaced the oil pump with a new OEM pump. The light still flickers. WTF? What am I missing?
Anyone else got an opinion?
Back tires, smoke em if you got em!
Road assistance on the list
and my homepage too!
Old 26th September 2010
nmbillb's Avatar
nmbillb nmbillb is offline
Sportster/Buell Model: XL883C
Other Motorcycle Year: 1996
nmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud of
Best suggestion is to get an actual oil pressure guage that will screw into where the oil sending unit (oil pressure switch) goes, and read the real pressure.
Bill in Southern New Mexico - '99 XL883c
I miss Mr. Jimi!
RIP BryanEOD
When I carry a gun, I don’t do so because I’m looking for a fight, but
because I’m looking to be left alone. - Marko Kloos
XLF Road Help [URL]http://xlforum.net/forums/showthread.php?t=670716[/URL]
My recent accident [URL]http://xlforum.net/forums/showthread.php?p=4397043#poststop[/URL]
Loner's Avatar
Loner Loner is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2012
Loner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant future
If oil pressure is good, you could have a shorting wire, loose blub or the as has happened to me one time the idiot light panel came loose and was causing my lights to flicker, but that does not seem likely since your are only getting just the oil light I would venture as a loose bulb or a shorting wire.
"I don't photograph in Black & White because I'm artistic, I'm colored blind"- unkown.
Old 4th October 2010
unionthug's Avatar
unionthug unionthug is offline
Sportster/Buell Model #2: Fat Deuce and Fat Boy
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Streetglide
Other Motorcycle Year: 2008
unionthug is an unknown quantity at this point
Most Likely the switch is bad, toss it out and get a gauge.
Old 5th October 2010
Smokin Sam's Avatar
So I got it figured. Inside the oil filter housing is a steel threaded insert that the filter screws on to. It comes out and there is a "ball and spring" set up that controls the pressure to the switch. A couple of things can happen. The plastic ball can get a groove pounded into it, the spring can sac out or it is possible to install it all backwards and have it "kinda work" as the threads are identical on both sides of the threaded insert. The hole is different on each end.
Yes a pressure guage and a double coupler so you can see where the switch trips helps.
In this case the ball and the spring were sacked. Once replaced it was good to go.
Old 7th October 2010
richard58 richard58 is offline
Sportster/Buell Model: XLH a red one...
Other Motorcycle Model: 78 Superglide, 97 Dyna
richard58 is an unknown quantity at this point
U might have the motor idling too slow also....
Old 8th October 2010
Smokin Sam's Avatar
A good point. Book says 1000rpm. That seems a little high. I like around 900.
