0 1967 XLCH stroker project
0 Fact or Fiction - HP Claims
0 NewProject
Last Post: Rodzilla
Last Post: vagrant318
0 Cylinder Piston kits
0 Thinking about buying a Ironhead
Last Post: ericfreeman
5 Pre-Oil the motor somehow after long Non-running?
0 Trouble Code B1611?
Last Post: Jcolleyoh
5 Wasted spark ?
Last Post: Magneto Sportster
0 surges and/or hunting on 1200 EFI's
Last Post: whittlebeast
Last Post: kaveebee
0 More of a reintroduction
Last Post: k9unitb
0 Iree's jukbox joint
0 900 heads contd..
Last Post: spacecoast
0 Battery life with total loss ignition
Last Post: Diogenes415
Last Post: lugster
0 Viking bags??
Last Post: gravydog
0 the far west burbs of Chicago
0 Diagnostic help
Last Post: BradX13
Old 27th September 2010
RGT's Avatar
RGT RGT is offline
Sportster/Buell Model: XR 1000
Other Motorcycle Model: Enfield
RGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the roughRGT is a jewel in the rough
Default '77 transmission thrust washer thicknesses
I putting my transmission back together and into the bike and I would like to know what the thicknesses of the Main Shaft Thrust Washer, the Main Shaft Third Gear Washer, and the Main Shaft Roller Bearing Washer are. I have various washers that came with the bike, some new some old. I put the bike together without the Main Shaft Thrust Washer by mistake and had too much main shaft end play, .018" instead of the .003"-.009" spec'd in the book. When I took it back apart I realized my mistake, but the only washer I have that fits that spot is .040, I did try this but find that my main shaft and clutch shaft bind and can no longer spin freely if I try and tighten down the cover, I see there are 2 Main Shaft Thrust Washers, the one with the tab that goes alongside the main shaft 1st/low gear is easy to identify so I think that one is ok, its the one that fits up against 4th gear that the main shaft bottoms out against that I measured at .040"....
asasial's Avatar
asasial asasial is offline
Sportster/Buell Model: 1200c 1980 chopped frame
Sportster/Buell Model #2: Ironhead chopper
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Nightster GF's Bike
Other Motorcycle Year: 2008
asasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to all
they come if different sizes so you can get the proper spacing between gears and endplay. one of the thrust washers will go on the outside of the trans behind the sprocket and between the circlip and bearings. if ya forget that one it will mess up the mainshaft, bearings and race at least.
