0 05 and 73
Last Post: N8DIESEL
Last Post: The Crusher
0 If you have European tilt
0 Tool Roll Help
Last Post: RökkenRöll
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
Last Post: Moon Wolf
0 Back in Sporty Land
Last Post: skien
0 WTF Happened
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The country store
Last Post: lugster
Last Post: Xl-1250r
Last Post: jcro61
Last Post: Titaniumrust
Last Post: screndname
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 79 ironhead
0 2016 48 Hesitating
Last Post: 201648Rider
300mm, hagon shocks, nightster
Old 19th October 2010
Hildreth's Avatar
Hildreth Hildreth is offline
Hildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really niceHildreth is just really nice
Default Hagon Type A
I FINALLY got my Hagons! I'm so pleased with my overall experience with them. I got the 300mm type A road shock with the 20kg spring, I weigh 170lb, no luggage, no passanger. First thing I noticed, wow, the shock actually sags (rider sag), like a shock is supposed to, those stock shocks were useless. now i've got around 3" of shock travel! so great.
I thought that putting a longer shock on my Sportster was going ruin the look, but I was wrong, it looks fantastic and they work like shocks ought too! whoo hoo...I should have done this two years ago!
oh ya and all those pot holes, ya what pot holes? There is such an improvement & no more grinding metal!
KevinJ's Avatar
KevinJ KevinJ is offline
Sportster/Buell Model: White Hot Denim XR1200X
KevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud ofKevinJ has much to be proud of
Looks great!
And its nice to see a shock upgrade that doesn't come from progressive suspension.
FourSpeedSteve's Avatar
FourSpeedSteve FourSpeedSteve is offline
Sportster/Buell Year: 1988
FourSpeedSteve is on a distinguished roadFourSpeedSteve is on a distinguished road
Sweet. Hagon are 40 minutes from me. I'm having mine made in front of me, I can't wait!
Your bike looks great!
What did they end up costing in dollars? I gotta fork out £210 for mine which I don't think is bad for shocks made to my spec.
LIVE LIKE YOU'RE DYING!!
1988 Four Speed chain Drive 883 Hugger. Screaming Eagle Carb, Andrews N2 Cams and Screaming Eagle Exhausts. Motul 7100 4t 20w50 with Activ8 in the oil tank and Amsoil 20w50 in the Trans/Primary.
steelworker's Avatar
Other Motorcycle Year: 2016
20kg springs sound hard. What length are the shocks?
I recently sold a pair of Hagon Nitro stainless shocks that were fitted with 18kg/cm springs - the lightest available for that model shock - and I found them to be massively over-sprung. My bike is probably lighter than the Nightster, but I'm 30lbs heavier than you; and those shocks, even with minimum preload, had very little rider sag and regularly had me out of the saddle on bumpier roads.
Old 28th November 2010
ahthisguyhere ahthisguyhere is offline
ahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the roughahthisguyhere is a jewel in the rough
i run those shocks on my bonnie and was very pleased with there service.
Old 4th May 2012
darsolo darsolo is offline
Sportster/Buell Model: iron
Sportster/Buell Year: 2012
darsolo is an unknown quantity at this point
883 iron . if i fit 300mm shocks will my side stand be ok
Old 4th May 2012
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
The actually have a US distributor in San Marcos California as well.
http://www.hagonshocksusa.com/
I have a set to install on my Sportster, they cost $218.00 shipped, and were custom assembled to my weight and riding style.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 5th May 2012
07XL1200N 07XL1200N is offline
07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice
Do you have any pics?
Old 6th May 2012
Hildreth's Avatar
I bought my shocks from the guys in San Marcos, I lived in the area so I just rode down there and spoke with the guys in person. Cool people. Here's the photos. Sorry I forgot I deleted my original post photos.
Old 6th May 2012
Are they 13"?
