0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 25th October 2010
HOMER308's Avatar
HOMER308 HOMER308 is offline
Sportster/Buell Year: 1961
Other Motorcycle Model: Harley Electrglide Classi
Other Motorcycle Year: 1986
HOMER308 will become famous soon enoughHOMER308 will become famous soon enoughHOMER308 will become famous soon enoughHOMER308 will become famous soon enoughHOMER308 will become famous soon enoughHOMER308 will become famous soon enoughHOMER308 will become famous soon enough
Default Kickstart problem #2 - starter gear/ratchet plate - what do I have here?
If you've have followed my other thread (kickstart issues #1 involving my kicker gear setup), I've been trying to get my '61 rolling - had been told that the kick would skip erratically and that it was probably the kicker gear, so I replaced it and after installation, it initially seemed much better with positive engagement. So, after getting the primary reassembled, I tried to fire the beast for the first time after rebuild and ended up getting a nice case of "Sportster knee".
After trying to heal, I decided to pull the primary down (again). When I pulled the guts from the primary, I find that the starter gear and the ratchet plate currently in the bike are COMPLETELY DIFFERENT for everything I've seen so far!
For comparison purposes, here is a ratchet plate on an early clutch basket:
Here is what is currently installed on the bike:
As for the starter gear, this is what I can find looking in catalogs and on Fleabay:
This is what is currently on the bike:
I guess my question is - what part numbers do I have here??? Everything I have seen so far is a 9 tooth ratchet plate and 9 tooth starter - looks like both of mine are 18 teeth!
IF anyone has seen this before and knows what part numbers I am dealing with I would appreciate knowing! It would seem to me that I might be better off with a 9-tooth setup than this - also, the starter gear seems to be awful loose on that spacer; you can definitely see it when the gear is restrained by the cam plate on the kicker gear with the kick lever in the upright position.
Does anyone know what the clearance between starter gear and spacer is supposed to be?
Any comments or info is appreciated - I'll get this thing ironed out yet!
1961 XLH Sportster
1986 FLHTC ElectraGlide
Old 26th October 2010
Rogotek Rogotek is offline
Sportster/Buell Year: 1964
Sportster/Buell Model #2: Shovester
Sportster/Buell Year #2: 1971
Other Motorcycle Model: Triumph 955
Other Motorcycle Year: 1998
Rogotek is on a distinguished roadRogotek is on a distinguished roadRogotek is on a distinguished roadRogotek is on a distinguished roadRogotek is on a distinguished road
18 teeth should be better than 9, but tolerance / clearance and positive teeth contact have to be spot on - Iam with the forum can solve this Mystery !!!
asasial's Avatar
asasial asasial is offline
Sportster/Buell Model: 1200c 1980 chopped frame
Sportster/Buell Model #2: Ironhead chopper
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Nightster GF's Bike
Other Motorcycle Year: 2008
asasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to allasasial is a name known to all
more teeth more engagement i'd like to know who makes your setup. if ya find out please let us know.
tom gordon tom gordon is offline
tom gordon is an unknown quantity at this point
to many teeth,the 9tooth works much better,been there and done that,i though the same thing,more teeth would catch better,wrong, then on mine,i cut the mating on both gearings so they wern't flat,i cut them with a die grinder to CUP them, no more sportster knee.IHTOM
the cowboy way's Avatar
the cowboy way the cowboy way is offline
Sportster/Buell Model: hand built M/XL ironhead
Sportster/Buell Year: 9293
Sportster/Buell Model #2: 1976 motor in a 1987 fram
Sportster/Buell Year #2: ????
Other Motorcycle Model: 1974 XL & 2003 FXD
Other Motorcycle Year: 7403
the cowboy way has disabled reputation
we need pictures of this
Forever Two Wheels
1997 AMRA National E-class Champion
Ironhead parts I have tons of em
machine shop @ home
Sportster/Buell Year: 1972
If you look at the "What Fits What" book they write about an early fine tooth kicker ratchet and a later coarse tooth kicker. The book says the fine tooth ratchet is a knee buster as you have found out. I would put in the the coarse set, the rivet pattern should be the same
HOMER308's Avatar
Many thanks guys for the input! I've inspected the bearing surfaces of these parts and they are all in good shape. I measured the internal diameter of the starter gear bushing - it came in at 1.365" I.D. - the spacer that the bushing is installed over (a 1.025" length short-style), measures 1.356" O.D., so we're looking at 0.009" clearance.
I don't have access to factory specs for these items, but it seems that there is too much slop so the gear can get cocked when operated.
With the cam plate holding the starter gear in its rest position, I measured the distance from the end of the spacer back to the top surface of the ratchet teeth - where it is held by the cam plate I measured 0.214" - on the side opposite it's only 0.187" - appears that it's cocked about 0.027" across the face of the gear.
I'm thinking the bushing is too loose and/or the spring is not strong enough to force good engagement, so I'm thinking of replacing both. FWIW, the spring has a free length of 1.593" (again, I don't know what it should be).
If anyone can tell me what kind of clearance the new bushing needs, I'd appreciate it! Seems most of the ones available come tight and have to be reamed out to proper dimension.
Thanks again everyone!
ChopperEd's Avatar
ChopperEd ChopperEd is offline
Sportster/Buell Model: Sportster XLCH
Other Motorcycle Model: 1995 FXDWG
ChopperEd will become famous soon enoughChopperEd will become famous soon enoughChopperEd will become famous soon enoughChopperEd will become famous soon enoughChopperEd will become famous soon enoughChopperEd will become famous soon enough
The spring is the first thing I'd replace. I did on my 73 and that was the problem.
1995 Dyna Wide Glide, Vance&Hines Long Shots, Jims lifter blocks, pushrods, cam, top end, Twisted Spokes.
1981 Sportster, Carlini Super Sweeps, everything else is stock.
HOMER308's Avatar
About the cheapest part too, eh?
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
From what I remember, the new ratchet gear I installed had about .001" clearance or so - just by feel. Certainly not enough to feel any rocking movement. Just enough to let it slide freely and that is all.
I would say my old worn out one had like .010" clearance, so it slipped.
Dunno the spring length but it is a common problem so worth getting a better one if you can.
