0 05 and 73
Last Post: N8DIESEL
Last Post: The Crusher
0 If you have European tilt
0 Tool Roll Help
Last Post: RökkenRöll
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
Last Post: Moon Wolf
0 Back in Sporty Land
Last Post: skien
0 WTF Happened
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The country store
Last Post: lugster
Last Post: Xl-1250r
Last Post: jcro61
Last Post: Titaniumrust
Last Post: screndname
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 79 ironhead
0 2016 48 Hesitating
Last Post: 201648Rider
110, 19 inch, metzler
Old 29th October 2010
DF-SLICK's Avatar
DF-SLICK DF-SLICK is offline
DF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to behold
Cool Fatty Front Tire
Ok did the 110 MM Metzler on a 19 incher deal and I have to say that I LOVE IT!
not only does the front end look much more beefy but it rides so much better now. I like having mo rubber under the front forks, YES! Did several sweepers, on ramps, off ramps, some with rain groves and it felt like I was not pushing hard enough, amazing. I did have to install the front fender AFTER I put the wheel/tire combo on and I stretched the fender mount flanges apart too to try to get better than 1/16th inch clearance. wow tight, but this gap will wear open soon. Photos attached, the old 21 incher looks like a bicycle tire/wheel now in comparison. Thanks to the Forum I now have decent rubber on the front end and better handling too. Sweeeet.
2005 XL1200C. Vance & Hines two into one exhaust system, Mikuni HSR42, Stainless braided Throttle and F-Brake & Clutch lines, PM Front Caliper, EBC Floating front rotor. Round NRHS Air cleaner. F/Fork Intiminators, Ricor 13.5 rear shocks, Super Brace. Works Performance Front Springs. TC88A with Rico's Jester ignition maps. NRHS Stainless Oil Filter.
cowboy770's Avatar
cowboy770 cowboy770 is offline
cowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of light
Looks good!!
Strangeman of the Gas Guzzlers MC
04 1200R N4 cams, custom A/C , stage 1 P&P, porker switchblades, Tc88a with Ricos Hooligan map, 185 main, 48 slow, and custom 5.2 gal tank. 3-1/2in extended forward controls, Enough about me, tell me about you.
SuicideCharley's Avatar
SuicideCharley SuicideCharley is offline
Bike Builder
SuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to all
DAMN IT! I was trying to avoid this over the weekend! I just received my 19" wheel last night...debating on the 110 no mo'....where di you get the rubbah?
Richies Armor Richies Armor is offline
Sportster/Buell Model: 1977 Ironhead
Sportster/Buell Model #2: 200 XLC Sportster 883
Other Motorcycle Model: 1995 HD Bad Boy
Richies Armor is an unknown quantity at this point
That looks great!!
Im doing this as well. I picked up a good deal on a 130 AVON on a 3.4 x 18" wheel at a recent swap meet. Im having to add the sportster hub and relace it with Buchannans spokes but I wont be in it too much dough. I did sand off the fender mounts and shave down the outter most lip of the tire with a planer to get a couple more MMs of clearnace. Ill post pics as soon as the wheel gets back from powder coating.
Richie
Doc45 Doc45 is offline
Sportster/Buell Model: XL1200R again!
Doc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud ofDoc45 has much to be proud of
Interesting, Metzeler's website no longer recommends the 110 for the front (on my '06 R anyway). I went with the 100 when I put on tires on in August. Also love the 880s and improved ride/handling.
DF-SLICK's Avatar
Thanks guys, Hi BurpleHugger. I got the rubber from Motorcycle Superstore, about 139.00 with shipping, got it all, Tire, Wheel Spoke inner skin, inner tube for 139.00 includes shipping two days. There's only about 1/16 inch clearance between the Fender brackets and the sidewalls. No contact on the sidewalls or tread edge though from my 60 mile test drive, some hard cornering and sometimes up to 90+ MPH. All feels very stable now, this also adds to a recent E Type HD fork oil and Progressive f/springs install.
flashedwards's Avatar
flashedwards flashedwards is offline
flashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant future
In real numbers how much wider is it than the original? It looks great. By the way, how much clearance do yo have between fork legs? I was wondering if it is the same as on my '09 Nightster? The stock tire is about 4 inches sidewall to sidewall with 5+ inches between the fork legs and 5/16" clearance from each sidewall to the fender struts.
Flash
Trying to balance being an "unknown quantity" and a "known associate" ....it's tuff
2009 XL1200N Nightster...SE Heavy Breather>SE SP black slip-ons w/modified Cycle Shack baffles>Speedway Instruments MicroTach+>Super Brace>Kriss headlight modulator. Willie G skulls @ gas cap,derby and timer>Misc. black nut and bolt covers>Garage Leathers solo bag>Mustang Vintage 12.5" solo seat>LED taillights>10.75" RK air shocks>G2 Ergonomics Quick Turn throttle>Power Commander V>Giving 10R12 plugs a try.
76 HP X 79 TQ
Ol' Dirtbeard of the Cracked Craniums MC
BillieB BillieB is offline
BillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enough
Each to his own. I like the narrow front tire.
Old 30th October 2010
DF-SLICK's Avatar
I'm not sure how wide the Nightster tire is Mine was a Dunlop 90mm, I went with the 110mm Metz and I have approx 1/16 inch clearance between the fender brackets and the edge of the tread. Had to mount the fender after putting on the new tire wheel combo and stretch the fender brackets apart some. But It works out very nicely, rides real nice too. The overall height diff, ground to axle is about 1/2 inch higher. So I basically maintained my rake & trail numbers.
