Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Service > Sportster Motorcycle Recall Info > 2000's Sportster Recalls
0 Value of a Boattail?
Last Post: valvebeater
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 Paulie420 needs your help.
Last Post: Paulie420
0 1977 Bright Blue
Last Post: Airarbiter
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Not charging issue!
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
Old 17th October 2007
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
Other Motorcycle Model: Road Glide
Other Motorcycle Year: 2011
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
Default 2005 Sportster XL1200R, XL883R Recall- HYDRAULIC:MASTER CYLINDER
Make : HARLEY DAVIDSON
Model : SPORTSTER 1200R, 883R
Year : 2005
Manufacturer : HARLEY-DAVIDSON MOTOR COMPANY
NHTSA CAMPAIGN ID Number : 06V201000
Mfr's Report Date : JUN 02, 2006
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
Potential Number Of Units Affected : 9506
Summary:
ON CERTAIN MOTORCYCLES, THE FRONT MASTER BRAKE CYLINDER ASSEMBLY HAD BEEN BUILT WITH INADEQUATE LUBRICATION ON THE SECONDARY CUP. THIS COULD CAUSE THE SLIDING RESISTANCE OF THE PISTON TO BE EXCESSIVE, WHICH IN TURN COULD CAUSE THE RETURN OF THE PISTON TO BE SLOW UPON RELEASE OF THE BRAKE.
Consequence:
THE PISTON MAY NOT RETURN COMPLETELY. IF THIS HAPPENS, THE REAR BRAKE LIGHT COULD REMAIN ILLUMINATED WHICH COULD CAUSE A CRASH OR INJURIES.
Remedy:
DEALERS WILL REBUILD THE MASTER CYLINDER. THE RECALL BEGAN ON JULY 10, 2006. OWNERS MAY CONTACT HARLEY DAVIDSON AT 1-414-343-4056.
Notes:
HARLEY-DAVIDSON RECALL NO. 0125. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Recalls Documents
RCQPR-06V201-5959.pdf Quarterly Performance Report
RCRN-06V201-6096.pdf Renotification Notice- May 18, 2007
RCMN-06V201-6176.pdf Manufacturer Notices(to Dealers,etc)
RCQPR-06V201-3117.PDF Quarterly Performance Report
RCQPR-06V201-4864.PDF Quarterly Performance Report
RCQPR-06V201-4173.PDF Quarterly Performance Report
RCRIT-06V201-4154.pdf Remedy Instructions and TSB
RCRIT-06V201-3246.pdf Remedy Instructions and TSB
RCONL-06V201-1135.pdf Owner Notification Letter(Part 577)
RCAK-06V201-1833.pdf Recall Acknowledgement
RCDNN-06V201-7079.pdf Defect and Noncompliance Notice(Part 573)
AMA #961454
