0 Stock 883 cold blooded
0 1977 Bright Blue
0 Not charging issue!
Last Post: Jowniofownio
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
Last Post: jammantoo
Last Post: lugster
Last Post: lugster
0 79 ironhead
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 20th December 2004
chieftd's Avatar
chieftd chieftd is offline
Sportster/Buell Model: XLH Sportster 883/1200
Sportster/Buell Year: 1989
chieftd is an unknown quantity at this point
Default Have a 1200 conversion now, is a 1250 or 1340 conversion worth the trouble and $$$?
Hey folks, just wondering from those in the know if this is a worthwhile endeavor? Here's my set up so far:
Thunderstorm Heads
Buell Pistons
SE bolt in cams
SE performance ignition
SE performance coil
SE air breather kit
Dynajet kit for the carb, new jets
V&H 2-1 Pro pipe
putting out 82 hp and 72 ft lbs as set up.
I got some cash burning a hole in my pocket and was contemplating MORE HP!
If I went with either upgrade could I leave everything else the same and still be compatible?
Are the bolt on kits the way to go?
Would the HP gain be worth the $$$ spent?
Which would you recommend to do or should I just leave it alone and buy some shiny shit for the bike?
Many thanks in advance. regards, chieftd
gwcrim's Avatar
gwcrim gwcrim is offline
Sportster/Buell Model: 1200 Sport
Sportster/Buell Model #2: Cafe el Roadkill
Sportster/Buell Year #2: 199?
Other Motorcycle Model: KX520
Other Motorcycle Year: 1989
gwcrim has disabled reputation
More cubic inches is always a good modification. But going to 1250 now is a waste of money. But anything larger requires splitting the cases and boring the spigots to accept BIG jugs. If you're going that route, you'll want to go with an 88" kit.
~Crim~
My photo gallery: http://xlforum.net/photopost/showgallery.php/cat/500/ppuser/184]
dmraco's Avatar
dmraco dmraco is offline
Sportster/Buell Model: Sportster Forty Eight
Sportster/Buell Year: 2012
dmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of lightdmraco is a glorious beacon of light
NOS or supercharger. a 6 speed would be cool to
Old 21st December 2004
Narley's Avatar
Narley Narley is offline
Narley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura about
heads flowed and a nitrous kit will make your bike 110 hp and 100 lbs...whats your compression? My 80/80 engine hits 113hp/108 tq on juice.
chieftd's Avatar
Default Narley, I don't know the compression numbers
unfortunately, I'm not mechanically inclined at all. I had a friend of a friend do the work and he didn't tell me much about it in terms of compression. I bought TS heads and Buell pistons and then had the jugs bored. It runs fine but I don't know the specifics. I know....I'm a dumbass, but thats me!
I still have my heart set on doing a street tracker conversion so I guess the curent power output is sufficient. I just got in touch with a guy today that said he would do the work so I plan on talking to him this week to get some ideas and prices.
Thanks for your inputs, hell I might find a way to rig a nitrous bottle on it but I'm a bit leary of them things simply because I have never used it and don't want to blow the motor up or hurt myself!
We'll see how it goes. Later, chieftd
Turbota's Avatar
Turbota Turbota is offline
Got money burning a hole in your pocket?
NALLIN RACING
NEW! 1430cc BIG BORE KITS FOR THE 2004 & UP SPORTSTER
http://www.nallinracing.com/index.shtml
From $1195
Turn your new XL into the absolute nastiest hot-rod around! Just introduced, these kits take your Sporty out to the maximum bore size you can get in your stock cases. Of course, this engine kit comes with the finest quality components money can buy: all-aluminum nik-a-sil plated cylinders from Axtell, matching forged Hurricane pistons with tool steel wrist pins, Total Seal rings, and Cometic EST gaskets!
Note: case boring is required for installation. $275
twinsporty's Avatar
twinsporty twinsporty is offline
twinsporty is an unknown quantity at this point
Holy S#$T a 87 cubic inch sporty. That sure would be fun and just think of it those BT wouldn't have jack on you with that power to weight ratio.
Old 22nd December 2004
SportsterSpive's Avatar
SportsterSpive SportsterSpive is offline
Sportster/Buell Model: XL883 w/NRHS Stage 3 1250
Sportster/Buell Model #2: XB9SX CityX
SportsterSpive is an unknown quantity at this point
WTF? I am sorry, but I sufficiently scare myself every day with 76ci.
--Sean
"The Rubber Rocket" - 97.4 hp/80.9 tq
'04 883/1250 Stage 3 NRHS Conversion
Forcewinder, Mikuni HSR42, Supertrapp 2-1, SE .575 cams, TC88A ignition, 1200S forks and shocks, Chainsikle rear seats, eBay Clip-ons
"The City Hero"
'06 Buell XB9SX CityX
Buell Race kit, some othe things
Luckymic's Avatar
Luckymic Luckymic is offline
Sportster/Buell Model: 883C/1250
Sportster/Buell Model #2: 1200C/1450
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Fatboy
Other Motorcycle Year: 2000
Luckymic is an unknown quantity at this point
I think I'm just an adrenline junky, cuz I want one. Sure I scare the piss out of myself on a regular basis, but I could still use an extra 11 cubic inches . You just cant have a bike with too many Cubes
[COLOR="Red"]Ride It Like you Stole It!!! [/COLOR]
03 1250 stage III...Hell yes it's fast
04 1250 stage II...blown up, 88 inch in the works.
00 1550 Fatboy...The Bus
