0 Brake Squeek
Last Post: Tucsonmax1
Last Post: cazz1000
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Old 23rd February 2011
73Harley 73Harley is offline
Sportster/Buell Model: Harley Davidson
Sportster/Buell Year: 1973
73Harley is an unknown quantity at this point
Default 73 Ironhead oil change help
Any information on changing the oil on a 73 Ironhead Harley Davidson would be great.
superwarden's Avatar
superwarden superwarden is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLC
Other Motorcycle Model: FXSTD
superwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of light
What do you want to know? Drain the oil out of the tank, refill with new.... If you are looking for specifics it would be good to know if you have aftermarket filters etc... It really is pretty straightforward though.
Just don't ask this crew which oil is best
Any date that is not on your tombstone is considered a lucky day.
doodah man's Avatar
Default uh-oh...
...to avoid the huge and imminent oil debate read this...
http://xlforum.net/forums/s...88#post1959688
it has everything you're looking for, and welcome aboard from fredericksburg virginia.
caution! do not stop on tracks.
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
Awwww. No oil debate? Greetings from Pittsburgh.
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
On these older bikes since they didn't have a oil filter it was recommended to rinse oil tank out with kerosene that was to get the sludge from bottom of tank.
Murphy's Law :vvet:
Welcome! to the IronHead forum.
If the bike is new to you it would be a good idea to do the kerosene rinse as recommended by ezmerf one time in case it was not done in the past. With modern oils it is not necessary to do it every time.
Mr Bentwrench's Avatar
Mr Bentwrench Mr Bentwrench is offline
Sportster/Buell Model: 1200 Sport - 4 Plug
Sportster/Buell Model #2: Triumph T-Bird 900 Triple
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Wife's T-Bird 900 Triple
Other Motorcycle Year: 1995
Mr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to beholdMr Bentwrench is a splendid one to behold
I've read the sticky a few times and just to confirm that on the early models specifically with the oil transfer valve we can now use the 'new' HD transmission oils and not the same engine oil anymore as originaly spec'ed way back in the early 70's?
Also, sticky pictured "HD Formula+" and my (copyright '86) Clymer lists "HD Power Blend Super Premium oil". No oil controvery here but being careful over subtle differences between these two... if any.
Ivan RoachCoach's Avatar
Banned
Default Yes, oil transfer valve is SUPPOSED to keep...
...the motor & trans/primary fluids separate, by acting as a crankcase-based vent for the primary, which allows the use of the Harley Formula Plus (used to be knows as SportTrans).
Unfortunately, oil transfer valves tend to f@#k up and become two-way valves --- this allows motor oil to seep into the primary, which oil-soaks the clutch plates.
The next time you're in the primary, hit the center orifice of the valve with a spot-weld and seal the offending little shit up.
oldnavy's Avatar
oldnavy oldnavy is offline
Sportster/Buell Year: 1972
Other Motorcycle Model: FXRS Low Rider
Other Motorcycle Year: 1986
oldnavy is on a distinguished roadoldnavy is on a distinguished roadoldnavy is on a distinguished road
The Formula+ is the choice of many on the forum and is what I use for the tranny and primary. I don't think the Power Blend is even available anymore. The transfer valve you mention does leak in many cases, so it is possible to cross dilute if you are running a different oil for the rest of the engine. Some have (ME too) sealed off the transfer valve as it was eliminated in later ironheads, and have no ill-effects.
Old 24th February 2011
Thanks for the info. That helps alot. And thanks for the welcome all. This is a great site. Always owned a Japanese motorcycle so new to the Harleys. If anybodys knows where the best pricing is to get a motorcycle lift, either jack or air.
