0 What's your helmet?
Last Post: Jheitt
Last Post: hscic
Last Post: Hellbent_4
Last Post: MCCoy
0 The Welsh Way, 21st April 2018
0 Show your tank decals
Last Post: kap
0 Tuning
Last Post: XLXR
0 Spokes or Mags
0 New in NM
Last Post: spoon
Old 19th October 2011
SNMbass SNMbass is offline
Sportster/Buell Model: XL1200C 105th Anniversary
SNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura aboutSNMbass has a spectacular aura about
Default Does Your EFI 1200 Do The Herky Jerk With Throttle Just Barely Cracked?
Does your bike do this too?
Conditions: Any gear, but for example, 2nd gear, about 2,000 rpm and holding (throttle just barely open)
Symptom: frequent but not cyclical "stumbles" - i.e. feels like fuel or ignition just cut off for a tenth of a second then came back on.
Get above about 2,200 rpm and it stops.
I've had this issue since new. 3 different dealers have said it's "normal" for EFI Sporties. I'm starting to believe it's true.
I've tried to tune it out using the SEPST with no luck. Ultimately gave in to dealers' suggestions to dyno-tune. Still does it. The guy who actually runs the dyno says can't get rid of it - it's the nature of the beast for EFI Sportsters, which seem to use less sophisticated programming than Big Twin EFI.
gchristopher9 gchristopher9 is offline
Sportster/Buell Model: 1200c
gchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nice
My 07 1200C stumbles as well. Been tweaking my cobra module trying to get rid of it for months, but nothing has helped. Good luck..
SpaceAce's Avatar
SpaceAce SpaceAce is offline
Sportster/Buell Model: XL1200N vivid black
Sportster/Buell Model #2: XL883N candy orange
Sportster/Buell Year #2: 2013
Other Motorcycle Model: Xl1200N RIP
Other Motorcycle Year: 2008
SpaceAce will become famous soon enoughSpaceAce will become famous soon enoughSpaceAce will become famous soon enoughSpaceAce will become famous soon enoughSpaceAce will become famous soon enoughSpaceAce will become famous soon enough
look into the dynojet powervision it fixed the problem you are talking about plus no need to go to dyno shop you have it right on your bike. you can tweak everything plus you can read and clear check engine or stored codes. well worth the money
knucklehead of the Cracked Craniums MC
Old Goat Ninja's Avatar
Old Goat Ninja Old Goat Ninja is offline
Sportster/Buell Model: XL1200R SOLD
Sportster/Buell Year: 06
Old Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to all
Just an FYI, 2000rpm is lugging the engine and will cause "herky jerky". Get those rpm's up. A carbed (like mine) will do the same thing at a steady 2000rpm. It's not good for these motors. You're actually hurting the engine at constant 2000rpm.
Old Goat Ninja = user formaly known as Starleak
Crosshairs's Avatar
Crosshairs Crosshairs is offline
Sportster/Buell Model: Its Black and shiny
Crosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond repute
Was just going to post the same thing..my bike no longer does it.....even down to about 1500 RPM its still steady
The dealer calling it normal just mean its normal for the EPA tune that the bikes come with..I'm surprised your dyno guy could not tune it out...
Yes, but if your in traffic in 1st gear and just barely moving, you have no choice but to run at that RPM.....sure you could fan the clutch, but with a proper running bike, you don't need to do that.
and at 2000 RPM your not lugging the engine unless your trying to quickly accelerate in the wrong gear ....my bike pulls just fine from 2000 RPM in 1st 2nd or 3rd gear ..4th or 5th and it will lug
lfvc77 lfvc77 is offline
Bike Builder
Sportster/Buell Model #2: XL883 SOLD
Other Motorcycle Model: Suzuki Inazuma GW250
lfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant futurelfvc77 has a brilliant future
Mine does it too, lean fueling to pass emission tests, EPA and CE requirements.
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
FWIW mine fine.
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
See the "Stumble on Cold Start-up" sticky fourth from the bottom on the main page.
I've tried to tune it out using the SEPST with no luck. Ultimately gave in to dealers' suggestions to dyno-tune. Still does it. The guy who actually runs the dyno says can't get rid of it - it's the nature of the beast for EFI Sportsters, which seem to use less sophisticated programming than Big Twin EFI.[/QUOTE]
Big twins don't use a more sophisticated program, in fact it's basically the same with just a few more features. The stumble can be tuned out, mine was with a SERT.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
Teehaml's Avatar
Teehaml Teehaml is offline
Sportster/Buell Model: XL1200C (Traded in)
Other Motorcycle Model: Yamaha FJR1300A
Other Motorcycle Year: 2014
Teehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond repute
No stumbles here...
Tom...
whittlebeast's Avatar
It just needs tuning. The problem is you bought a tuner that needs a $25000 dyno and a guy that understands what he is looking at.
Beast
