0 1967 XLCH stroker project
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 New to Harley
0 79 ironhead
0 THE Trainspotting Thread
0 rpm jump pulling in clutch
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
0 Value of a Boattail?
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
Last Post: jammantoo
Last Post: lugster
Old 15th February 2012
kino44's Avatar
kino44 kino44 is offline
Sportster/Buell Model: 1200cc
Sportster/Buell Year: 1988
kino44 is on a distinguished roadkino44 is on a distinguished roadkino44 is on a distinguished roadkino44 is on a distinguished roadkino44 is on a distinguished road
Default rear Chain sprocket size?
Im replacing my rear sprocket it is a 48 tooth and my front is a 21 tooth CHAIN DRIVE. bikes a 1988 883 with a 1200 conversion are these stock sizes? I do have high RPMS around 60-70 so could I change the rear sprocket to get lower RPMS would I need to go with less teeth or more teeth or should I just stick with the 48 tooth? would 1 extra or 1 less tooth make a difference?
THE SUN DOESN'T SHINE ON THE SAME DOGS A** EVERYDAY
rottenralph's Avatar
You either have to go bigger on the front or smaller on the back. I think my 93 five speed has 23/48 which gives a 2.08 to 1 you have 2.29 turns of the front for one wheel rotation. This will reduce rpms by 10%.
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I believe the 21/48 combo is stock on Sportsters with chain drive from the 1980's-on. One less tooth on the rear won't make much difference, but one (or two) more on the front will. I run a 23 front sprocket on mine, and it's turning about 3000 rpms at 60 mph.
kino44's Avatar
Default front sprocket
so like a 49 or 50 tooth in rear wont make any difference? so your running a 23/48??
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
If you put a 49 or 50 on rpms will raise at highway speeds. Put on a 47 in rear or 22 or 23 infront.
83XLX's Avatar
I'm running a 23/49 on mine. Originally I just replaced the front sprocket with a 23 and still had the 48 on the rear. When I needed a new rear sprocket, I bought a 49 because the 23/48 gearing was just a little to high for the hilly area where I live. If I had it to do over again, I would have probably just bought a 22 front and 47 rear, because the 23 required a little grinding on the backside of the sprocket cover to fit without rubbing.
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
I did 22/46 on 1988 with 1200 conversion with ported head. Runs strong.
Nice on the highway.
kino44's Avatar
Default rear sprocket
So if I use a 47 with my 21 I should be ok? the RPMS arent to bad I really never go over 60 or 70MPH so a 21/47 should work fine?
Old 16th February 2012
That will give you a 2.24 to 1 gear ratio. Divide the big by the small and you get the ratio. I matched mine to stock belt gearing when I made my choices. Your current setup is 2.28 to one which is not much of a change.
gypdawg's Avatar
gypdawg gypdawg is offline
gypdawg will become famous soon enoughgypdawg will become famous soon enoughgypdawg will become famous soon enoughgypdawg will become famous soon enoughgypdawg will become famous soon enoughgypdawg will become famous soon enough
Im running a 23 front, 47 rear, i can cruise at 70 all day long at low rpm's.
"Life is what you make of it"...make mine LOUD,HARD,AND FAST!
