Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
Last Post: Screw Loose Dan
0 Primary Oil INSANITY!
0 Lowboy frame conversion
0 What jets do you use?
Last Post: David L.
0 FNG from OKC
Last Post: David L.
0 Show your tank decals
Last Post: Tonail
0 Solar battery charging
Last Post: Ranchero50
Last Post: Naplesron
Last Post: Grumpy-Biker
Old 23rd March 2012
K Beggs's Avatar
K Beggs K Beggs is offline
Sportster/Buell Model #2: XLH Chopper
K Beggs will become famous soon enoughK Beggs will become famous soon enoughK Beggs will become famous soon enoughK Beggs will become famous soon enoughK Beggs will become famous soon enoughK Beggs will become famous soon enoughK Beggs will become famous soon enough
Default 15-1 thru 15-4 cams
Anyone know what kind of cams these are? They look like a Sportster cams but I can't find information on them.
http://www.ebay.com/itm/300654755701...84.m1439.l2648
Old 23rd March 2012
Big-Ed's Avatar
Big-Ed Big-Ed is offline
Sportster/Buell Model: Sportster Sport XL1200S
Sportster/Buell Model #2: Fatboy 1450 FLSTFI
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Kawasaki KDX125sr
Other Motorcycle Year: 1991
Big-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to all
They are sold now, but think that they were/are the SE bolt-ins aka SE.497's
1998 XL1200S - Harley 2-1 fitted with V&H SS2R, SE race ignition (7500rpm) with matched SE coil, SE yellow leads, NGK Iridium spark plugs, NRHS HurricaneFlow 3" centre hamcan filter, usual 'S' engine internals (w-grind cams, flat top pistons & 10:1 higher comp twin plug heads), SE heavier clutch spring. Soon to have SE 42mm hsr mikuni carb..
Old 23rd March 2012
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Yes, many of the SE bolt-ins are marked 15-1/2/3/4. But some are marked 1B/2B/3B/4B
Click Here to Contact Me
Old 23rd March 2012
K Beggs's Avatar
Cool, I went ahead and bought them. Figuring that if nothing else they'd make great paperweights.
ASWRacing,
I read your article on Cam Drive Gear Swapping, I have an 01 model and they look to like they came from a 99 and older... yes? Also, looking at the pics, are they overheated based on the discolorization of cams 2 and 3? Thanks!
Old 23rd March 2012
aswracing's Avatar
Yes, those are 91-99 cams and yes, someone spun their bushings in the right case half, and yes, it looks like some of the gears got really hot.
Your first challenge will be to get those cam bushings off. I've seen those things seize really badly. Assuming you can get them off, try to clean the journals by clamping the other end into a lathe. Use fine emery cloth working down to scotchbrite until they're shiny again. I've done it and got them to work again.
Hopefully the teeth on those aren't brittle and prone to breakage, but I have no way of knowing.
Yes, to put that set in a 2000-up you can swap the drive gear, either that or get a new pinion gear. Swapping the drive gear is definitely cheaper.
Old 23rd March 2012
Do you really want to risk damaging your expensive engine so you can use a cheap set of cams? Those cams are just a disaster waiting to happen IMO.
Old 23rd March 2012
K Beggs's Avatar
Nope, they sure will make good paperweights though.
Old 23rd March 2012
glad you saw the light.
Old 24th March 2012
K Beggs's Avatar
Yea, like i said. They would've either worked or made great paper weights. For $37 it was worth a shot, but not enough to trash my motor.
Old 5th September 2012
markncarj1's Avatar
markncarj1 markncarj1 is offline
Sportster/Buell Model: xl883/1200c
markncarj1 is on a distinguished roadmarkncarj1 is on a distinguished road
So i am reviving this thread. i got some 15-/15-4 buell cams and i have a 2002 sportster. i need to change the drive gear. in the instructions mentioned above it says on the gear there is a v or an o. I think the ones i have have a v on them. also how does someone know the gear i in the right place to begin with? they have been marked so i am worried the drive gear could be in the wrong place to begin with
