Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 Brake Squeek
Last Post: Tucsonmax1
Last Post: cazz1000
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Old 5th September 2012
on sportsers you use the O marks not the Vs.
markncarj1's Avatar
markncarj1 markncarj1 is offline
Sportster/Buell Model: xl883/1200c
markncarj1 is on a distinguished roadmarkncarj1 is on a distinguished road
so i will not see the o marks on the buell cams?
most of the buell cams have both Os and Vs
markncarj1's Avatar
are the o's the marks used for alignment?
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Yes.
Here is everything you ever wanted to know about XL cam installation.
Click Here to Contact Me
Or you can also go here:
http://www.nrhsperformance.com/tech_xlcaminstall.shtml
markncarj1's Avatar
perfect!! thank you very much, my cams have no v's so pretty simple. now just got to find a press. i read somewhere that it may not be nessessary to pull the rocker boxes, is this true if they are bolt ins?
aswracing's Avatar
Yes, absolutely, you must remove them. This section of my current cam installation article is specifically about bolt-in cams and it covers this, I highly recommend you take a few minutes and read through that section.
No that is not true. you must pull the rocker boxes to remove the cams
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
im supprised your going with theys cams when there is a lot better out there for a good deal dan at nhrs sell cat 3 cams good cams. hammer performance sells there new crush cams these 2 cams make good power and dont cost to much$$ you might want to look at there sites before you instale . just sayin.?
