Last Post: Grumpy-Biker
0 Salutations y'all
Last Post: Alias Bob
0 no rear brake light
0 67 Sportster build
Last Post: ldurmon
Last Post: geoff
Last Post: goblin_dust
0 What's your helmet?
Last Post: lucky23
Last Post: cotton1
Old 30th March 2012
Erbie's Avatar
Erbie Erbie is offline
Sportster/Buell Model: XL1200N Org/Blk
Erbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond reputeErbie has a reputation beyond repute
Default Chrysler Clunk
Sorry, this could get a little lengthy to be clear.
On my 2003 Concorde, I've had a distinct clunk in the front passenger side wheel/suspension area for a while. It occurs under cornering or straight line braking. I've read where it could be a number of things from control arm bushings to coil over mount bushings. I never really understood how it could be suspension with it happening in straight line, but what do I know. Now over lunch I pulled the tire to check the brake pads. I decided after getting the wheel off that I would check the bearings by wiggling the hub. Grabbed the rotor to do that, and while the hub was nice and solid, the rotor moved out about 1/4 inch on the back side opposite the caliper. Now I know I've got to replace it, but that leads to my questions. How hard is it to get the rotor pressed on, and could that solve my clunk?
Thanks
Adam
Erbie
2007 Nightster Orange Pearl/Black
Nothing too special. Willie G Skull accents, V&H Slip-ons w/ "Quiet" baffles, Hammer Impact A/C, Power Vision, flipped mirrors, adjustable road pegs, SuperBrace, LePera Barebones.
Old 1st April 2012
aemsee's Avatar
aemsee aemsee is offline
Sportster/Buell Model: xl883c
aemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond repute
that rotor isn't pressed on and it is fine that it moved like that. Is the noise a reaction to suspension movement, like hitting a pothole or going over a bump?
Old 1st April 2012
Erbie's Avatar
Yeah, found that out about the rotor. Thanks though. Glad that I don't have to replace it, but still concerned about the clunk. I'm pretty sure now that it's suspension related. I've been told that the sway bar links have a tendency to go bad on these, and it could be that. The only problem is that I'm not sure how to check it, and I don't want to just start throwing parts at it. I've also heard it could be any number of bushings including one on the coil over mount. Guess I'm going to just have to suck it up and pay someone to take a look at it. Really wish I was back home. Pretty sure I could get it looked at for a little bit of nothing. Maybe I can wait until next weekend since we're heading back that way for Easter.
Old 1st April 2012
aemsee's Avatar
do you know what the sway bar links are? If you do you can reach past the wheel and tug on them to see if they move. Usually when they are bad they will rattle back and forth by hand. These cars are also known for tie rod ends rattling
Old 1st April 2012
wedge's Avatar
wedge wedge is offline
I agree, and he can jack that wheel off the floor and while he is looking under it he can have someone else move the wheel around back and fourth, top to bottom, etc. Also a pry bar under the jacked up wheel may be able to reproduce the noise and he can look while a buddy does that part. (Best to put a solid jack stand under that side while he does it though).
Old 1st April 2012
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
A couple things.... first you may not find worn suspension part lying on your back...weight of the vehicle will keep some components loaded and you wont be able to see it. Also some shops may check your car for free or small charge with hopes of getting the repair. Someone may check and let you know what youproblem is.
Denny
Old 2nd April 2012
Erbie's Avatar
Thanks for all the help guys. I'm pretty sure I know what the sway bar link is, so I'll give a couple of those checks a try, and if not, I'll find some place that can a look at it.
Old 4th April 2012
DG_Sportster's Avatar
DG_Sportster DG_Sportster is offline
Sportster/Buell Model: 1200 Sportster C
DG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to beholdDG_Sportster is a splendid one to behold
The inner tie-rod ends on those cars are notorious for going bad....really bad. It's actually not a tie rod, but a rubber bushing, and when it wears it allows a ton of slop. It also allows all sorts of shimmy/wobble/wander problems. It's not too hard to fix....actually easier then conventional tie rods IMO.
Read: http://www.allpar.com/fix/intrepid-steering.html
Don't know if this is really your problem, but when i hear of clunks on these cars, this is the first thing i check. As mentioned, the sway bar links also wear.
The water-logged OEM starter/system relay on 2007-2009 Sportsters is a OMRON G8H-UA-007401, but this can be crossed over to some automotive apps: Borg Warner R3154, Gp Sorenson 41-5154, Niehoff RL 35381 are examples. Good luck!
Old 4th April 2012
Erbie's Avatar
Originally Posted by DG_Sportster View Post
The inner tie-rod ends on those cars are notorious for going bad....really bad. It's actually not a tie rod, but a rubber bushing, and when it wears it allows a ton of slop. It also allows all sorts of shimmy/wobble/wonder problems. It's not too hard to fix....actually easier then conventional tie rods IMO.
Don't know if this is really your problem, but when i hear of clunks on these cars, this is the first thing i check. As mentioned, the sway bar bushings also wear.
Tie-rod ends/etc, are on the short list of things to check, but it's not at the top since I don't have any of the shimmy/wobble/wonder issues as of yet. I'm hoping it's not anything that will also involve getting an alignment done.
Old 4th April 2012
cotnballs's Avatar
cotnballs cotnballs is offline
cotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nice
Right, jack the car up and get a large crowbar. You then can put pressure on the parts and check for play. Check ball joints also just to make sure before you buy parts. The other guys are probably steering you in the right direction already.
"For those who care, I do not"
