Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
  #791
Old 16th July 2012
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
Originally Posted by ~Grind~ View Post
I'm thinking about re-installing the stock lifters into the motor. From what I understand, the JIMS lifters have an extra oil hole in them that may lower the oil pressure. If this is true, this may be contributing to the excessive noise in the valve train. When the motor is cold it's relatively quiet. When the oil gets hot and thin the motor gets pretty noisy. This condition may allow the plungers to bottom out. ? There is only one way to find out. But first I need to lengthen the anti-rotation flats on the stock lifters to accommodate these RS-585 cams.
I plan on doing the same thing, just based off of bad reviews I've read about JIMS powerglide lifters
Old 16th July 2012
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
grind i don't think that the oil hole bleed off is the problem if any thing its a good thing, if you valve get louder when hot you push rods aren't long enough take the covers of the top i know its a lot of work and measure the lift with a dial indicator and make sure you are getting max lift any time you change cams and lifter you should do this.
Old 18th July 2012
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
I understand where you are coming from Bob, I just don't see the point when using hydraulic lifters. However, there is a good chance I'm missing something. Anyways, I did remove the rocker covers and rocker boxes. I had already clearanced the pushrod side of the covers and didn't see any sign of abrasion upon inspection of both sides of the covers. I spot checked the gap between the head and the rocker box/gasket with a dial caliper. The dimension on both heads was well within the specs described in the tech article on the Hammer Performance website. I did find another one of my screw-ups on the front rocker box though. I found some slight abrasion where the exhaust valve spring was rubbing the rocker box. I thought I had given the springs plenty of clearance... evidently not. So I got out the die grinder and fixed it. The rear box was fine. I then put it all back together and took it for a 20 mile ride. It was still noisy as ever when I got back so this Friday I'm going to install the modified stock lifters and give them a go.
"Only Fools Celebrate A Fool"
Old 18th July 2012
Bob s hog's Avatar
the reason im telling you not to you wont get what you want by going backwards measure your lift on your rocker i think your push rods are to short you must measure your lift to see if your getting wear you need to be it easy and can save time and money measure your lift and times it buy 1.652 should give you your lift if you do not come up with that numer on you cam card your to short or to long and that will make your valve train very noiesy.
Old 18th July 2012
Ok Bob, I do have the indicators. Where on the rocker is the best place to take the measurement?
Old 18th July 2012
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
Hey Scott, how long are your pushrods? Here's the ones I got with my package from Hammer:
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 18th July 2012
Bob s hog's Avatar
if you can at the tip of the rocker is the best spot buy if not go wear the ball fits in your rocker and measure from there its going to be a pain to do, but if i could put my hand on any thing i would check this first i think they are a little to short which is good and bad good if its the problem bad you wont have full power yet .
Old 18th July 2012
Bob s hog's Avatar
i just checked my cams in my lath i have a reading on the intake side and theys are 585 red shift cams my reading was .365 times that buy 1.62= .05913 now on my cam card it sayed i get a advertized .583 lift which id say is pritty close my other intake is the same my exhaust read .360 times 1.62 = 583.2 so if you come up with theys number id say your good to go.
Old 18th July 2012
Bob s hog's Avatar
all right i just measured all my the numbers look like this
.365
.365
.360
.361
is what iv got for numbers.
Old 18th July 2012
Ok, Thanks Bob. I will check it out as soon as I get time.
