0 strange small wires attached to coil
0 24633-77 Breather assembly
Last Post: ericfreeman
5 Transmission HELP!
Last Post: Twistedrench
0 Sportster or Street Bob
Last Post: Baby883
0 Ei
Last Post: tvon
0 Solar battery charging
Last Post: tvon
Last Post: wachuko
0 primary chain temp.
0 2016 48 Hesitating
Last Post: XLXR
Last Post: prahxy
Last Post: hhugger
Old 20th May 2012
cgp-1200R's Avatar
cgp-1200R cgp-1200R is offline
cgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to beholdcgp-1200R is a splendid one to behold
Default Starter Does not engage Please Help
I would like some opinions.
My 06 1200R 35k miles started showing a problem. intermittently the starter does not engage. I replaced the original batter, cleaned all the connections but it still is doing it.
1) Can I do something else before i rip it open.
2) Continuing to ride it make it worse ?
3) The moter seems fine, should I just replace the clutch and Solenoid ?
Anything else. ???
The older we get the further away we get from who we think we are
Patriot Guard NY Region 2
SAL SQN 366 Honor Guard Color Guard
Old 4th June 2012
cgp-1200R's Avatar
Parts on order Starter Overrun Clutch and gaskets.
Old 5th June 2012
xlron's Avatar
xlron xlron is offline
Sportster/Buell Model: 1100
Sportster/Buell Year: 1987
Sportster/Buell Model #2: 1000 xlh
Sportster/Buell Year #2: 1980
xlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to all
At 35K, that's what you need bro. About how many times do you estimate you crank it for every 100 miles on the odometer?
Old 5th June 2012
cgp-1200R's Avatar
Thanks xlron 2x/100 mi I comute 55 miles each way to work. Getting the Terry clutch.
Old 5th June 2012
rsinghal3 rsinghal3 is offline
rsinghal3 will become famous soon enoughrsinghal3 will become famous soon enoughrsinghal3 will become famous soon enoughrsinghal3 will become famous soon enoughrsinghal3 will become famous soon enoughrsinghal3 will become famous soon enough
Mine was doing the same thing and it was indeed the starter clutch. I went ahead and replaced the whole starter as the stock ones are made with needle bearings and the one I replaced with contains ball bearings. Supposed to have a much longer life, but we will see. Hope you get it fixed and running soon.
Rahul Singhal
Mechanical Engineering Student Georgia Tech
Harley XL1200N
Old 6th June 2012
cgp-1200R's Avatar
Thanks ! !!!!
Old 11th June 2012
Thorsxl Thorsxl is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 1990
Thorsxl is an unknown quantity at this point
Hi, which starter did you choose, it seems like i have a simlilar problem, whats the best aftermarket one out there?
Old 11th June 2012
morvenhouse's Avatar
morvenhouse morvenhouse is offline
morvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud of
Many good reports about the All Balls 1.4Kw starter but I have just ordered an Ultra Chrome 1.4Kw from Eastern Performance Cycles. I would have gone for the All Balls version but everyone (including All Balls) are showing no stock so I guessed it may be some time before it shipped. I'll post once I have received and fitted the new starter.
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
Old 11th June 2012
cgp-1200R's Avatar
The terry clutch is in and working great... No more Clunk on Hot starts
Old 12th June 2012
cgp-1200R's Avatar
I only replaced the clutch $100 and then $ 25 for the gaskets and $9 for the fluid.
