0 Diagnostic help
Last Post: BradX13
Last Post: RKN
0 Head gaskets.
0 The country store
0 So Cal Ironhead Gathering
Last Post: leucadiaGuit
Last Post: cotton1
Last Post: mct496
0 headight housing
Last Post: The Doctor71
Last Post: cotton1
Last Post: cotton1
Last Post: cotton1
0 Hope Cove, 20th May 2018
Last Post: seajay
0 oil cooler or not?
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Pender1
Last Post: MatHormell
0 A Day in the Life...
Last Post: cotton1
Last Post: cotton1
Last Post: lugster
Last Post: lugster
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
Old 28th May 2012
XLXR's Avatar
XLXR XLXR is offline
If I remove the fuel line from the tank and put the petcock on reserve, should fuel flow out without putting vacuum to the smaller line?
I'm not sure about reserve. Put a clean tube on it and suck on it.
Old 29th May 2012
Sporty B Sporty B is offline
Sporty B is on a distinguished roadSporty B is on a distinguished road
I took the petcock off and checked it. The fuel flows good with vacuum applied. I have checked the diaphragm, set the carb settings to the recommended settings per the jet kit, checked the plugs, fuel, no intake leaks. I am done. I will be calling my local dealer tomorrow to set up an appointment. Thanks to everyone who helped me.
Old 29th May 2012
rick szymanski's Avatar
rick szymanski rick szymanski is offline
rick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to behold
a Really fast way to check if it's a lean condition, possibly cause by wrong float setting, or accelerator pump not working is to start the bike. Throttle up to where it starts running poorly, and spray carb cleaner into the air cleaner inlet. If it smooths out, then it obviously is a fuel issue. This is of course assuming that there are absolutely no vacuum leaks at the intake or around the carb base and all vacuum lines are good and hooked up properly. If the float isn't allowing enough fuel to be stored in the bowl, then it will try to run, but quickly turn to crap. without actually seeing the problem in person, its difficult to make the best suggestion, but this is what I would try. Likewise, if you suspect too much fuel to be a concern, create a vacuum leak to see if things improve. If so, then jetting could be an issue or float is set incorrectly.
Old 18th June 2012
RustyNuts's Avatar
RustyNuts RustyNuts is offline
Sportster/Buell Model: 883
RustyNuts is on a distinguished roadRustyNuts is on a distinguished road
Did you get the issue fixed what was the issue?
I always wanted to do TWINS!
Old 19th June 2012
shotgun46's Avatar
I was also wondering. If it was solved ?
Sent from my LG-VS700 using Tapatalk 2
Sportsters Rule ! :banana
Old 19th June 2012
WinterWheel's Avatar
WinterWheel WinterWheel is offline
WinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud of
It's not because of an unvented(clogged or incorrect) gas cap, maybe?
I don't want to simply be alive. I want to feel alive!
I prefer to ride the Stallion, not the Plow horse!
