0 900 heads contd..
Last Post: Keithybloodygeorge
0 Oil Tank question
Last Post: jordan1200
0 1967 XLCH stroker project
0 Fact or Fiction - HP Claims
0 NewProject
Last Post: Rodzilla
Last Post: vagrant318
0 Cylinder Piston kits
0 Thinking about buying a Ironhead
Last Post: ericfreeman
5 Pre-Oil the motor somehow after long Non-running?
0 Trouble Code B1611?
Last Post: Jcolleyoh
5 Wasted spark ?
Last Post: Magneto Sportster
0 surges and/or hunting on 1200 EFI's
Last Post: whittlebeast
Last Post: kaveebee
0 More of a reintroduction
Last Post: k9unitb
0 Iree's jukbox joint
0 Battery life with total loss ignition
Last Post: Diogenes415
Last Post: lugster
0 Viking bags??
Last Post: gravydog
0 the far west burbs of Chicago
0 Diagnostic help
Last Post: BradX13
Old 31st May 2012
tara's Avatar
tara tara is offline
Sportster/Buell Model: 1200 xl
Sportster/Buell Year: 1987
tara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the roughtara is a jewel in the rough
Default Big bang, detonation !
hey guys, finally i ve decided to start a thread.
the bike has started to misfire one week ago when hot. so we suspect a bad coil, but now it made big detonations. is it possible that detonations have their origin with bad coil ????
i have ordered a new coil today, a crane coil which would work well with my HI-4 crane module.
i have tested primary and secondary at the coil and both were between specs, but the coil was cold.
i tried to reinstall my old accel single fire which had problem 6 months ago, but was just misfiring, and now i had huge detonations and came back home after half mile...
i hope too that those detonations haven't damage my engine too
any ideas
thanks
tara
1986 frame - 1997 1200 engine stage 1.5 - N2 cams- single fire Accel - Crane hi 4 - big sucker - 23 T sprocket 48 T - Ohlins #3#3 13 1/4 - showa 35 mm Progressive spring - all brake system by Performance Machine second motor 86 4 speed 883conver 10.5 1200 V8 cams 1200 heads - tuned CV cards by killer motorcycle product -
Old 31st May 2012
wedge's Avatar
wedge wedge is offline
any ideas
thanks
tara
If I am thinking the right year, the 87 has a magnetic pickup right? Doesn't it also have that rotor with two slots cut into it? I saw recently in here where someone had a broken rotor, and also magnetic pickup's do go bad as well.
Old 31st May 2012
are you sure you do not have a blown head gasket causing this?
Old 31st May 2012
tara's Avatar
no, it is with my 1997 engine, not the older one
Old 31st May 2012
tara's Avatar
Dan i will check that again, but as far as i know, i haven't noticed anything around the head gasket.
do you mean detonation cannot be caused by bad coil ?
Old 31st May 2012
If you have a blown head gasket or a bad intake leak it will cause your bike to go really lean which will cause terrible detonation. That is what it sounds like to me not a bad coil.
Old 31st May 2012
tara's Avatar
Dan
much too lean, hum...
will search in that direction
intake seals have been changed recently cos i had already some problems with misfiring, popping at the end of last year
thanks
Old 31st May 2012
tara's Avatar
i have to precise, but i m sure you know already, those detonation happened under load only
Old 31st May 2012
wedge's Avatar
And only when hot, which is contrary to a head gasket that should get tighter with heat. It is very much like the pick-up though to do something like that when hot, and I sure wouldn't overlook air leaks either, that is great advice.
I think the 97 is similar too with a pickup and a rotor.
Old 31st May 2012
tara's Avatar
wedge, i made a test with my old single fire coil and remove the air filter. at idle it is ok, but when i open throttle i have spark coming out the carb, quite scary. it looks like kind of backfiring ???
