0 More of a reintroduction
Last Post: k9unitb
Last Post: 45Brit
0 crack in head
Last Post: slamtry
0 Clutch Spring plate poll
Last Post: NZstu
Last Post: 45Brit
Last Post: kaveebee
0 Cylinder Piston kits
0 Bars on C Riser?
Last Post: mattjs666
0 1967 XLCH stroker project
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
0 Fact or Fiction - HP Claims
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Last Post: kaveebee
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The White Bike is the Right Bike Thread.
Last Post: if6was9
Last Post: Slidesquad24
Old 4th June 2012
Jimmy_Hoffa's Avatar
Jimmy_Hoffa Jimmy_Hoffa is offline
Jimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to all
Default Has anyone noticed worse handling with a wider front tire?
When I bought new tires a while back they were out of 80/90-21s, so I got a 90/90-21 front. I noticed it seems to be giving me feedback in curves. Not quite death wobble. If I take my hands off at 70mph the bike gos true, but I just feel something weird with the handling, esp in curves. I know others are running much fatter tires, but can fat tires cause poor handling?
I'm not sure if I want to buy another tire yet.
Old 4th June 2012
yozer13's Avatar
yozer13 yozer13 is offline
Sportster/Buell Model: xlh883
yozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to beholdyozer13 is a splendid one to behold
did they balance the wheels when they did it? or if spoked could have tweaked the the rim a little giving it a slight buckle?
______________________
Old 5th June 2012
dwl25 dwl25 is offline
Sportster/Buell Model: xl 883c
dwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nice
I'm very interested in this as I've been considering doing just the same thing. What brand did you go with?
As a possible solution what tire pressure are you running? I'd get it up to around 38 psi and see if that helps.
Dave, Galveston, Texas (formerly Lake Perry, Kansas)
Old 5th June 2012
OK, I went from a stock 80/90-21 Dunlop to a 90/90 Shinko 777. Others have said it's a good tire.
I'm running 30~ PSI. Just checkede it.
I think the feeling I'm trying to describe is like it wants to follow every little line in the road or something. Wich is more likely to do that, skinny or fat tires?
Old 5th June 2012
axlespacer axlespacer is offline
axlespacer is an unknown quantity at this point
I run the 777 90/90 21" on my custom and love it! I think my handling improved dramatically. It takes much less input on the handlebars now to steer. I can steer with my weight now from the seat much easier.
Old 5th June 2012
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
When I went from a 80/90 21 to a 90/90 21 on my solid mount,
The handling improved.
Run 36 psi in the front tire, it will handle better (maybe 37 with the heavier rubbermount)
Ed
The Only Y2K dual-set 883C
So Cal
Old 5th June 2012
Strange thing with everybody telling me to run MORE pressure. I checked the tire the other day and it was at about 20psi, so I filled it to 31psi, then when I rode it, it was MUCH worse. I'll try 37~ and I'll try 20 again and see if I can dial it in.
Old 5th June 2012
I went and looked last night (with a flashlight) and the Shinko sidewall says max. inflation is 42psi WOW! So I put 42 in it. We'll see how it handles now. Unfortunately it's supposed to be raining here through the weekend :-(
Old 5th June 2012
03custom883's Avatar
03custom883 03custom883 is offline
Sportster/Buell Model: 883xlc Sportster 100year
03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about03custom883 has a spectacular aura about
On my 03 i run 30 -31 up front is that too little? It handles and rides fine
03 883 XLC, V&H pipes, Screamin Eagle, AC Carb rejeted,---SOLD!
Old 5th June 2012
norseXL's Avatar
norseXL norseXL is online now
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
Using a to wide tire on a narrow rim will make the tires profile more pointy and give a more nervouse feel.
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
