0 Vintage sportster saddlebags?
Last Post: jordan1200
0 03 xlh 88"
Last Post: conv90
0 Hello from Minnesota
Last Post: 1HD4CJM1X4K
0 Hello from Vegas
0 Lithium battery earthx
Last Post: jharback
Last Post: toe
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 This Mikuni vm38-9 is driving me insane
Last Post: cazz1000
0 Were your parents anti bike?
Last Post: jcn59
0 New Fuel Cap
Last Post: Maaske75
0 How stock is your bike
0 Keith Black Conversion
Last Post: Scuba10jdl
0 Question on a transfer valve
Last Post: Tator
0 New England 2018
0 2004 custom
Last Post: wongjohnson
0 Quarter turn throttle tube
Last Post: Kejobe
Last Post: kmul
0 Issues with threads on some colony parts
Last Post: DirtyHarry68
Last Post: TT60
5 Favourite grips?
0 Searching for a used Ironhead, my observations
0 Sportster tachometer wiring question
Last Post: Doc308
0 09 Buell XB12 crank
0 ***DK Custom-Limited Time 10% Savings on Rock-it Shift For Sportsters***
0 What color are your pipes?
0 Front brake shorting?
Last Post: Hughieboy
0 ***DK Custom-Limited Time 10% Savings on HALF-MOON FLOORBOARDS***
jdhickm (83), Chip (70), Chief4x4 (68), willyobiker (66), CBryant (65), XLCH69 (62), sage (59), VettesRule (56), jerseyjeff (56), TheExecutioner (53), SalTheWop (53), manic_mechanic, pauldmedic16 (44), BluegrassXL (40), Superman
Old 6th June 2012
big andy's Avatar
big andy big andy is offline
Sportster/Buell Model: xlch 73
Sportster/Buell Year: sold
Sportster/Buell Model #2: 1997 1200s
big andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond repute
Default head specs
Well just got a set of heads back for a motor im doing.Had four guides four valve seat inserts .All new valves as well all supplied by me .Got charged 750 bucks for the work which I thought was a bit steep but tried twenty or so machine shops including major engine rebuilders.And this guy was the only one that said he can do them.He said he has done plenty of shovel and pan heads before so i left them with him. Well having paid for work before and it was done wrong I thought well im not going to take his word that they are good to go.Keep in mind that I gave him my shop manual so he had all the correct specs.Well got up this morning and went to the shed and pulled the rear exhaust valve out to check the specs and guess what it aint right grrrrrrrr .minimum valve sticking out the head when measured from the shoulder of the guide is 1.375 ive got 1.345.wtf IM no engineer but I reckon the valves will hit the pistons.How the f---k do you get that wrong when ya have the specs in front of you .So ive got this right if there is less than the minimum there is to much valve in the combustion chamber . And a good chance they will hit the piston on compression stroke
1997 1200s 1250 Hammer performance kit . Hammer performance billet inlet manifold .Hammer performance billet pushrod tube holders. energy one extra plate clutch kit . bronze oil pump drive gear upgrade
Old 6th June 2012
erockwell's Avatar
erockwell erockwell is offline
erockwell is on a distinguished roaderockwell is on a distinguished roaderockwell is on a distinguished roaderockwell is on a distinguished road
Default Heads
For what its worth,I would clay the heads and see if they will hit.I paid 800 for mine to be done.Just told him I was running the r5 cams with wiseco forged,sent them out,3 weeks later,walla.PERFECT.Call Jim at Megaflo near pittsburgh.Hes a one man machine shop that has been producing top wins around the world for sportsters and shovels.He can help!!!
Old 6th June 2012
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
The max/min spec for valve stem protrusion is to insure proper rocker arm geometry, not piston-to-valve clearance.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 6th June 2012
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Are you guys seriously saying you are paying $750.00+ for a simple valve job?
No high flow porting or flowbench work, no hardened seats, and you said you supplied the valves and springs?
Old 6th June 2012
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
If you're going to pay those prices go to Baisley and get hot rod head work for the same price. While you're there get some roller rockers too.
Old 6th June 2012
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud of
WTF he's been sodomized for a head rebuild and now you want him sodomized for some roller rockers?
Seriously it's only off .030" What's .030" among friends?
Old 6th June 2012
tracbike's Avatar
tracbike tracbike is offline
Sportster/Buell Model #2: Sportster XLH
Sportster/Buell Year #2: 1977
Other Motorcycle Model: Trac Dynamics / Razor,
tracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the rough
We have said this over and over and over.....along with Flohead works....
Oh No not again ok I will shut up.... But they save money in the long run.
I will say that there are guys charging 550 or so and it is the complete package plus they usualy blend the pockets and bowl.
Andy the way you measure and what guides used might be wrong/right, I'm not sure unless I see a lic of what your doing. But over all the Rivet is right about that
Old 6th June 2012
waza's Avatar
waza waza is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: 1978 FLH Shovelhead
waza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nicewaza is just really nice
wow. That's a lot of money to fit parts for 4 valves.
Old 6th June 2012
fdny37's Avatar
Hey tracbike the vein on your farhead is popping out.
Old 6th June 2012
erockwell's Avatar
Default headwork
Ill have to chime back in.He did do a complete rework and changed the geometry on the valves and seats and reworked the bowls.It was well worth the price.Simply suggested a call to him for technical help
