0 TC88A maps for 1250 Sporty
Last Post: Yellowstone Kelly
Last Post: Diogenes415
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Old 10th June 2012
1200 Custom's Avatar
1200 Custom 1200 Custom is offline
1200 Custom is on a distinguished road1200 Custom is on a distinguished road
Default clutch noise
Any ideas ???? 02 1200 Custom 75000 miles... Just started having a light clunk noise when i let out the clutch in first gear... Don't do it every time but often... Checked clutch adjustment and it was good... Bike rides great still but i'm not liking this noise... Any ideas???????
Seems like a gear clunk and only does it one time when lever is released....
Old 10th June 2012
xlron's Avatar
xlron xlron is offline
Sportster/Buell Model: 1100
Sportster/Buell Year: 1987
Sportster/Buell Model #2: 1000 xlh
Sportster/Buell Year #2: 1980
xlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to all
Hey Custom, Mine does it too,(2003, 883) so I put in new clutch friction plates, ajusted according to the book, and it still does it. So I,m thinking I'm going to pull it apart again & replace the "springplate" with more steel plates & frictions to make up the thickness of this thing. Because I cannot say for sure, but I think this is the problem. Mine does it only after its warmed up good, about 15 or 20 miles. It can be alieveated by being "extra careful " on the clutch lever release, but thats a real pain in the butt. I'll be interested in seeing more comments on this before I do the job. I may be totally wrong. See ya
Old 10th June 2012
Thanks XlRon....
On my bike it seems to be a *Clink or light clunk * coming from in frt of the clutch area and it does it when i release the lever..
Old 10th June 2012
Crosshairs's Avatar
Crosshairs Crosshairs is offline
Sportster/Buell Model: Its Black and shiny
Crosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond repute
could it be a loose primary chain ?...may explain why it only does it once when the lever is released
Old 11th June 2012
xlron's Avatar
Yes, if its in front of the clutch a loose primary makes more sense. Would be much better than a clutch problem. Got the book?
Old 11th June 2012
Yep i got the book... Would a primary chain to tight make a noise like this. I checked it and it seemed to tight to me so i adjusted it but have'nt got to ride it because its raining now ... I hopeing that could cause it???????
Old 11th June 2012
xlron's Avatar
A loose chain would be more likley to make a clunk type noise. A tight chain would be more of a humming, buzzing while moving. I believe at 75k, it would benifit your peace of mind to open it up and inspect it, and go ahead & change out the clutch pak ( the whole clutch), or the clutch stack (friction plates & or metal plates). You did the cover removal, screw to the left till it hits, back to the right 1 quarter? Or just tightened the cable?
