0 Tried to buy a new helmet
Last Post: kap
0 FNG from OKC
0 New in NM
Last Post: _Outlaw
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Tank swap
Last Post: Grymy
0 Lowboy frame conversion
Last Post: spacecoast
0 Primary Oil INSANITY!
0 What jets do you use?
Last Post: David L.
Last Post: David L.
Old 10th June 2012
Vermonter's Avatar
Vermonter Vermonter is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: 80XS650/71CL175/7?gs550
Vermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of light
Default New clutch time.
Rode to work and everything seemed fine, felt like a good ride, get on to go home and have zero clutch engagement. Check clutch adjustment and everything is correct. New clutch and clutch spring time I guess.
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." Thomas Jefferson
Old 10th June 2012
FearlessFrisbee's Avatar
FearlessFrisbee FearlessFrisbee is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1957
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Indian Scout 741
Other Motorcycle Year: 1941
FearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really nice
What changes that fast. It works one second then not the next?? Sounds more like something is broken or has come loose.
Does the lever have the same feel when you pull it in as it did when you got to work??
Old 10th June 2012
Vermonter's Avatar
Yah, I can feel it against the plates, it feels like its the same resistance, but I don't know. Steelership isn't open Mondays so I have time to take it apart to see what's up in in there before ordering parts.
Old 10th June 2012
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
I'm still betting on the actuator.
Old 10th June 2012
when you say zero clutch engagement, so u can roll the bike in gear? or do u mean disengagement?
Not to be picky but it does help us with troubleshooting to know exactly what the symtoms are.
Old 11th June 2012
Vermonter's Avatar
In gear I go no where when I let the clutch out. It's not engaging. I got half a block from work and shifted into second and it didn't accelerate when I got the throttle.
Old 11th June 2012
hcrashster's Avatar
Ain't the actuator. Gotta wonder if the outer drive plate or release plate is binding.
You have said nothing about slipping. I just can't see losing all your clutch facings at once.
Could also be some junk got jammed in there.
Old 11th June 2012
Well, I'd say get the rear in the air so u can spin the wheel and do a little checking but it sounds like you're going to have to get into the primary and inspect the clutch etc.
Old 11th June 2012
Vermonter's Avatar
I was thinking one of my springs might have broken. When I figure out how to get my bike home I'll be able to open it up and see. Apparently AAA plus doesn't do bikes like I thought it did, and there is a seven day waiting period to upgrade to the AAA that does bikes.
Old 11th June 2012
Oh man, I thought they did too, better check tomorrow, thanks for the heads up.
