Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 11th June 2012
williamv1203's Avatar
williamv1203 williamv1203 is offline
Sportster/Buell Model: 1203 XLH/Buell Hybrid
Sportster/Buell Year: 1988
Other Motorcycle Model: FXDWG TC88
Other Motorcycle Year: 2000
williamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to behold
Default Overdoing it!!!
Why on earth would anyone put a combination of 48/200 jets in an 883 that has only had SE 2 mufflers and air cleaner mods done to it?!
There was evidence of it being waaay rich, even with ~3 turns out on the air/fuel mix.
I took it back to 42/180 @ 2 1/2 turns for the time being...
Old 11th June 2012
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Probably some idiot who thought more gas = more power.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 11th June 2012
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Wow, that is crazy! Some people just don't understand. I bet he was the same type to whine about how crappy fuel mileage is and that HD's suck because of it...
Old 11th June 2012
trainman's Avatar
trainman trainman is offline
Sounds like it was jetted for 100% ethanol!!!
Old 11th June 2012
I agree with all that has been posted.
This 2003 883 XLH is a recent acquisition by my new GF/SO whatever it turns into. Still a new thing here.
When she got it home, she had battery trouble and a friend called me to come help get it started. When I got there, they were jump starting it and it would start then die. I walked up and pulled the choke out and told them to try it.
The next day I had a look over it and it was a rolling death trap waiting to snap.
On her way home with it, she told me that the clutch pivot pin had worked its' way up and almost out. The throttle assembly had started coming apart and when put back, I later found that it had jammed the brake light switch and it was on continuously. Every footrest bolt was finger loose. The forward control shift lever to the shifter shaft was spinning freely on it. Don't know how she managed to get through to any gears. Saddlebag supports were nearly falling off. Handlebar clamp was loose. A handfull of gear oil, which was emulsified, in primary. Engine oil was carbon dirty, looking and smelling like it had about 15,000 miles on it. Front brake pads were worn to about 1 mm. All this among other things I found and have now fixed for her.
Now you're thinking, "why didn't I go with her to get it?"
Well, truth of the matter is, I didn't know her until I got the phone call that night just over a week ago.
So, this neglected Sportster has brought us together.
Old 11th June 2012
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
[quote]
Sportsters, connecting people since 1957
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
Old 12th June 2012
Dakin Engineering Dakin Engineering is offline
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
Many "tuners" tried to fix the carb farts and flat spot in the stock tune by throwing bigger jets at it.
Get a N65C needle available at your local Kawi dealer....
Then adjust the jets back towards stock as needed.
Sam
Old 12th June 2012
Thanks, I'll try that. I think I have an N65C in my box of carb parts. I haven't looked to see what's in the carb just now.
As it stands with the 42/180 combination and decreased from 2 1/2 to 2 turns out, it is running quite well. I forgot to check the plugs after getting it home from where I have been working on it yesterday. They were a bit carboned up with 2 1/2 turns.
Old 14th June 2012
Scuba10jdl's Avatar
Just for reference. My 2002 with SE A/C and SEII pipes is running a 42/160 and 1 1/8th turns on the screw. It shows no signs of lean or carb farts at any throttle opening, and the plugs look great. Puts out about 55rwhp/53torque on the dyno with air fuel ratios between 13 and 14 consistently.
Old 14th June 2012
Hmmm...
I have a 160 jet and may try it in there. I did check the plugs and the electrode was brownish and the ring/base was a bit carbony with 2 1/4 or so turns out. If I remember correctly ?, this is a sign of it being a bit lean?
