0 Stock 883 cold blooded
0 1977 Bright Blue
0 Not charging issue!
Last Post: Jowniofownio
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
Last Post: jammantoo
Last Post: lugster
Last Post: lugster
0 79 ironhead
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 13th June 2012
ss243b ss243b is offline
Sportster/Buell Model: 78 sportster
Sportster/Buell Year: 78
ss243b is an unknown quantity at this point
Default problems help please
Ok guys just swapped the oil pump out, time all the cam gears thought i was good to go but when i put it in gear and turn the back wheel the cams dont move and obviously not the tappets either? Everything is on tooth but doing nothing any ideas
Old 13th June 2012
squirt squirt is offline
squirt is an unknown quantity at this point
Are you sure it's in gear? Are the pistons moving, or is the rear wheel easy to turn by hand?
Old 13th June 2012
piniongear's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
I assume (and hope) you do not have the pushrods in at this time.
It is always a good idea to have the timing cover installed before you go rotating the engine.
Not all the screws in but rather put the cover on the dowels and attach with 2 screws.
The timing cover is afterall the outer support for the cams.
So at this point I do not know what to say but I have a question for you: Did you time the oil pump breather tower?
That needs to be done when you have removed the pump.
pg
Old 13th June 2012
Its definately in gear and its hard to turn the wheel little easier with the clutch in
Old 13th June 2012
Its a 78 so no pump timing, i have the cam case back off right now, nothing moving, gears arent binded up, cant figure it out
Old 13th June 2012
piniongear's Avatar
What gear do you have it in?
In first you are going to have a really hard time turning it.
Put it in fourth gear.
pg
Old 13th June 2012
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
pg
Old 13th June 2012
I have tried in all gears, no movement
Old 13th June 2012
piniongear's Avatar
(1) Will the wheel rotate backward?
(2) Put it in neutral and see if the wheel now spins freely. If it does, then something in the engine is jammed.
If it does not rotate in neutral then look at the sprockets where the chain goes and see if there is not a nut or bolt causing the binding.
pg
Old 13th June 2012
Spins free in neutral, the tire will go backwards but is tough, no jams
