0 first harley- help!!
Last Post: rickthrash99
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
  #61
Old 15th June 2012
hugie03flhr hugie03flhr is offline
Sportster/Buell Model: Buell M2
hugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enough
How do you take the cams out without loosening all the push rods???
Old 15th June 2012
ss243b ss243b is offline
Sportster/Buell Model: 78 sportster
Sportster/Buell Year: 78
ss243b is an unknown quantity at this point
I took the push rods out
Old 15th June 2012
randy3934's Avatar
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
were you able to tell what caused the oil pump to fail?, Like Hopper said your pinion shaft may have sheared the key, if so the oil gallery for the crankpin won't be lined up, maybe you could get someone that has their engine apart to get the timing line centered in the hole and take a pic to see where the pinion gear mark is positioned.
Old 15th June 2012
It looked liked the pump itself was the problem, seen no unusual marks or anything inside the case, just got the bike to start 20 mins ago for about 15 seconds and then it died and couldnt get it going again.
Old 16th June 2012
randy3934's Avatar
is the accelerator pump working? are your plugs fouled? have you done a compression test? if that bike was running when the pump failed you might have bigger problems.
Old 18th June 2012
Plugs arent fouled, dont know what an accelerator pump is? Im new at this just trying to learn, the pump didnt work when i first fired it up after rebuild, i got it to start a few times but it wouldnt run for more than 10-15 seconds, cant figure it out, it sounds fine for no longer than it runs. Im lost.
Old 18th June 2012
randy3934's Avatar
remove the air cleaner, when you twist the throttle you should see fuel squirt down the throat of the carb, not sure which carb you have but I'm assuming it's a keihin butterfly, if you see fuel squirt do it a few times and try to fire it up while watching the oil pressure light, the bike should try to start and hopefully you see that light go out, if it doesn't I wouldn't run it.
Old 18th June 2012
randy3934's Avatar
If the bike fires even for just a few seconds and you see the oil light go out you need to rebuild your carburetor.
Iron mick has an awesome tutorial for your carb, I think this is it.
http://xlforum.net/forums/s...d.php?t=185361
Old 18th June 2012
nikki's Avatar
nikki nikki is offline
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
send us some pics that we can help you better. Nikki
the difficult can be done immediatey the impossible takes a little longer
Old 18th June 2012
Ok, its a super e carb, yes it squirts fuel fine, it is pumping oil now with the new oil pump(dont have an oil light yet). Like i say after the top end it ran fine, i didnt take it on the road or anything, i seen it wasnt pumping oil immediately. So i didnt run it long. Took the old oil pump out, toor the cam cover off to check all the teeth and make sure everything else was fine. Reinstalled cams. And thats where im at.
