0 Oil??
0 Rear tire
0 Salutations y'all
Last Post: cotton1
0 Show your tank decals
Last Post: cotton1
0 What's your helmet?
Last Post: cotton1
0 New England 2018
Last Post: joes95bobber
Last Post: cotton1
Last Post: RKN
0 Decman's Birtday
Last Post: Heff
0 67 Sportster build
Last Post: ldurmon
0 ##Dark side Tracker##Cam's ID?
Last Post: olddude13
Last Post: r4fthrs
Old 16th June 2012
billblack billblack is offline
billblack is on a distinguished roadbillblack is on a distinguished road
Default rear axle stuck
I attacked (among other things) tonight my rear brakes. I have new shoes that need installed. I remove the axle nut and attempted to drift the axle out: it wont budge. I put the nut back on loose and took some wacks with my 6 lb. maul and the axlle came out about 1/8 of an inch but that's it. IT feels like I am running into a steel wall. I assume it is rusted to a sleeve of some sort within the wheel.
Any tips on getting a stuck axle out? I have sprayed the assembly the best I could with wd40 (what I have sitting around( an am going to let it sit for a overnight. I'll pound on it again in the am and see what happens.
In the meantime: any tips for removing a stuck rear axle??
Old 16th June 2012
scottfisher's Avatar
scottfisher scottfisher is online now
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to all
PB blaster and let it sit over night.
Scott
'61 'CH
'60 'CH
Old 16th June 2012
sportsterdoc's Avatar
Other Motorcycle Model: Triumph Bonneville
Try some Liquid Wrench. You may get much better advice, but unless you can lift it up, turn it sideways, place it under a hydraulic press, I know only impact force, without damaging the threads (using a nut to protect them, as you are doing). That is what one H-D dealer did to my 2002...and then did not bother replacing the sealed bearings.
Old 16th June 2012
Good review at Home Depot...think I will buy some tomorrow...just to have.
Old 16th June 2012
The Doctor71 The Doctor71 is online now
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
The Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to behold
after you let it sit overnight, put a socket on it, from the left side. 1¼" socket should fit. Turn it CCW then CW then CCW etc. You know, rock it back & forth. Hopefully the axle will break loose and then you might be able to turn it out.
If it's really bad, you may need a buddy tapping it from the right side while you work the socket from the left side.
Old 16th June 2012
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Undo the brake anchor bolt.
Old 16th June 2012
ChinCactus's Avatar
If all else fails. I had this happen on my brothers 2000 xlc. After repeated applications of penetrating oil and the air hammer, we succeeded in mushrooming the axle. I then reached in from behind with a loooong sawzall blade and cut through the spacers and the axle.
Once the wheel was off the bike we could use the air hammer to drift what was left of the axle out. Obviously needed a new axle and spacer, but that was relatively cheap.
Apply never seize to the new axle!
Good luck,
Jim
Old 16th June 2012
ChinCactus's Avatar
Don't waste your time. When it seizes, it is the axle to the spacer between the bearings. it will turn with the axle. You can rock it back and forth till your face turns blue and it won't help.
Ask me how I know!
Old 16th June 2012
nikki's Avatar
nikki nikki is offline
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
Good luck,
Jim
+1 on the never seize years ago when I replaced the tires on my bike the old bkier who worked at the dealer told me to cover the axles in grease before I put them back. but the bikers who worked for the dealer at the time would tell me these tricks for it saved them time and saved me money if I needed them to work on it . Nikki
the difficult can be done immediatey the impossible takes a little longer
Old 16th June 2012
randy3934's Avatar
randy3934 randy3934 is online now
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
loosten the adjusters, also the brake backing plate bolt located just ahead of the axle on the swingarm right side, use a block of wood on the axle end and big hammer, spray with wd or pb work it back and forth it will come out. I'd replace them wheel bearings after hammering on them like that.
