Last Post: seanq2208
7 Long Road Trip advice
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
0 Leaks
Last Post: Steven2142
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
Last Post: 72 Ironhead XLH
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 99 1200s clutch drag
Last Post: NZstu
Old 29th June 2012
roachhill roachhill is offline
Other Motorcycle Model: Ducati Monster
Other Motorcycle Year: 1995
roachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud of
I would have been happy if my speedo could stay within 5 mph or so. Took me awhile to figure out mine was claiming I was going a good 9 mph faster then I really was. No wonder everyone kept passing me. The problem is you have a genuine factory gauge, LOL.
Old 30th June 2012
LuxBlue's Avatar
LuxBlue LuxBlue is offline
I know my speedo's accurate to 1 mph in 100 because I figured out the math by using my actual rear tire diameter and gearing ratios and knowing the number of teeth on the gear that the VSS reads. I then set my TC88A ignition to the correct corresponding Hz. When I ride with my buddy on his Softail, he's always claiming he's indicating 3-5 mph more than me. Our odometers are off too on a long ride by 3-5 miles out of 100.
Old 1st July 2012
tmack-1's Avatar
tmack-1 tmack-1 is offline
Sportster/Buell Model: Sportster XLH1100
Sportster/Buell Year: 1986
Other Motorcycle Model: Speedway Green Horm
Other Motorcycle Year: 1972
tmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to all
Said this before. You might not be 5 mph off. You could be 2-3 high and they could 2-3 low.
I know on my '04 Chevy pickup, speedo saying 55 is really only around 52 or 53 mph. Found this out using a stop watch and the mile markers on the interstate (60 mph is 1 minute to go 1 mile, 5 minutes 5 miles), then reconfirmed on the GPS and again on those goofy police speed warning things.
On my 86, the original speedo was basically "spot on" compared to the GPS. Unfortunately the needle fell off. The new speedo reads about 1 -2 mph slower than the GPS.
NOTE: comparing your speedo to a GPS is a pain in the neck. Since GPS units use averages over so many seconds, you have to find a spot that is flat and level so you can go a few miles at the same speed. Not as easy as it sounds.
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
Old 1st July 2012
ReddTigger's Avatar
Having worked for dealerships in automobiles, heavy trucks, school buses and motorcycles, 10% is considered normal operating parameters for any manufacturer.
States I've Ridden in
71.3 hp 70.8 tq
Old 1st July 2012
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
96+ have/utilize electronic speedos, 94's NOPE!
Old 1st July 2012
LuxBlue's Avatar
In this era of VSS (vehicle speed sensors) and PWM (pulse width modulated) data busses, it's not hard to have an accurate speedo...you just have to program the ICM or ECM to the correct VSS Hz.
Mechanical speedos?..... Harder to calibrate.
Old 15th July 2012
knut's Avatar
knut knut is offline
knut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to all
Really enjoy my 04' Sportster... but it has to have one of the most inaccurate speedometers I've ever encountered on a motorcycle... and that's sayin' something...
veteransforpeace.org
Old 16th July 2012
denguy denguy is offline
Sportster/Buell Model: 1200
denguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud ofdenguy has much to be proud of
All things considered, I wish they had stuck to the cable drive.
Old 17th July 2012
E65841 E65841 is offline
Sportster/Buell Model: xl1200 low
E65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the roughE65841 is a jewel in the rough
Question it is what it is i guess
Originally Posted by Motorhead52 View Post
Find a side of the road read out or time in a area with markers
mine is aout 1 to 2 MPH off low
Far too many riders have said they were doin 55 with me while my needle
is showing 50. I have gone through radar displays and I show 5mph slower
than what the radar displays. Not only that but the odometer ain't all that accurate either. FOR EXAMPLE: I have driven multiple vehicles from my driveway to a place down the road, and whatever vehicle it may be, shows from my driveway to that spot is exactly 8.0 miles. Not 8.1, or 7.9, but 8.0
consistantly. On the sporty though it is always 7.7 miles, that is 3/10 of a mile short for every eight driven. So basically for every 24.3 miles driven the
speedo is a mile short. but where I can't connect the dots is why do the rpm's on the tach match the displayed speed? ie: 60mph shows 3000 rpm,
If I,m actually going 65, which I am! Its a miracle I ain't been ticketed.
Old 18th July 2012
xjjoe01 xjjoe01 is offline
Sportster/Buell Model: xl883h
xjjoe01 is an unknown quantity at this point
My 93 sporty speedo is 5 mph slow as is my buddies 2007 dyna. I suppose it helps with the resale value....
-Joe
