0 Need advice (Falters When Turning Corners)
0 Spokes or Mags
0 -75 ironhead, My first HD
0 Riding on Blood Thinners
0 Touratech Destino Boots Review
Last Post: MotoMoshe
0 Lowboy frame conversion
0 How do you upshift?
0 Oil Hose replacement help.
Last Post: Jollly Rogers
0 Stage 1 results
Last Post: 09Nightsterrider
0 Want to buy: solo saddle bracket and hardware
Last Post: Dsantizo2
0 Forty-Eight Special and Iron 1200 Sportsters announced today
Last Post: Jheitt
0 Solar battery charging
drag pipes, ironhead, lollipops, magneto, xlch
Old 27th June 2012
plucinskid's Avatar
plucinskid plucinskid is offline
Sportster/Buell Year: 1965
Sportster/Buell Year #2: 1963
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1960
plucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura aboutplucinskid has a spectacular aura about
Default 65 XLCH XLR Exhaust Lollipop Cure
I was having issues with my 1965 XLCH. On the highway, the bike in 4th gear at 3/4 to wide open throttle would miss and sound like it was on a rev limiter, which I know it has none. I would lose speed, I could kick the bike down to 3rd gear, rev the bike up and muscle through the dead area but when I was back in 4th gear the bike and engine rev's would slow down at which I would roll back on the throttle and back into the area at which the bike would misfire again,repeating the kick down process. I installed the lollipops in my XLR drag pipes and wow did that cure the problem. Smooth running at highway speeds now, prior to this mod the bike was also a little peaky, like a two stroke engine.
I know this has been covered but thought I would post my setup and history for others.
1965 XLCH
.050 overbore
P cams
Magneto ignition with Joe Hunt Rare earth rotor
Big valve heads, ported and polished
Modern CV carb with acc pump.
Jetting 48 Pilot, 180 Main, 1988 Sporty pre acc pump needle, air screw 1.5 turns out
XLR exhaust pipes, with lollipops installed 3'' back at 90 deg
22 front, 51 rear sprockets
This is the how to lollipop link.
http://www.nightrider.com/biketech/exhaust.htm
Old 27th June 2012
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
I have zero drag pipe experience.
But the lollipops do work in muffled exhaust as well.
They really bump up idle to 4000 power, w/ only slight loss above that.
My experience is the fender washer needs to be 3/4 the size of the I.D. of the pipe.
Then you can turn the plates to get desired results.
Anything smaller does not work well, don't even try eyebolts, they don't have enough surface area.
Check my dyno links for lollipop dyno graphs.
Old 27th June 2012
bobber58 bobber58 is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of light
My engine is almost exact to yours except that I am running R5 cams and only need a 175 main jet with the Sporty needle, and a 21 toothe front sprocket. How do your plugs look? That main jet seems awfully big.
I was having the same problem with my home made shotgun pipes, so I installed a set of baffles. It cured that problem but created a new one, the sucker would not rev anymore. I would guess 4000 was all I could get out of it. The baffles chocked the engine so much it wasn't funny. So I removed the baffle, cut the very end off of it creating a ring with a hole in it that's about an inch and a quarter in diameter, and re installled this ring. Now I don't have that flat spot anymore, the bike damn near stands up when I jump on it, will rev to the moon, and my plugs look great. My pipes have a weird whistle at low rpm, but you can only hear it from the seat and it goes away as soon as you give it throttle.
Old 27th June 2012
plucinskid's Avatar
Plugs look good but after fixing the exhaust woes I plan to playing with a smaller main jet this week. Never had to deal with this exhaust issue before.
I ran a 48-185 on my last .030 over XLCH with stock heads.
Old 27th June 2012
Lollypops are a bandaid for an incorrectly matched exhaust system.
Sticking anything in a drag pipe is like trying to fart around a cork.
Old 27th June 2012
chevelle's Avatar
I understand what your saying, but disagree.
On the other end of the spectrum, most stock pipes are not well matched for the engines they came on.
They are great for noise control,not performance.
So what are we ironhead guys to do?
Pick some import bolt on "high performance" type exhaust out of a catalog and assume the exhaust manufacture (10 year old Chinese kids) know what their doing?
The lollipops work in muffled exhaust as well as I mentioned in my other post.
My take on Harley exhaust is performance,sound and looks.
Ream baffles (if muffled) to get the sound you want then tune w/ lollipops for desired back pressure.
I understand its not optimal and backpressure is a bandaid, but these engines are far from optimal as well.
I love the look of xlr pipes.
I'm not a fan of drag pipe noise and lowend power loss though.
To keep that xlr look (that I'm sure he is going for) and have a decent adjustable tuned exhaust w/ a $2.00 fix, that's ok in my book.
Old 28th June 2012
Why would you want to make them 1 3/4? That would suffocate the engine.
Old 28th June 2012
brucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud of
i,agree bobber58,3/4,the diameter of the pipe,i.d.,is what chevelle,stated. i,misunderstood what he was referring to.
Old 28th June 2012
chevelle's Avatar
For 1.750" drag pipes it would be about 1.180", try it.
It does not suffocate the engine, but I think Ive heard this before.....
Did you see the homemade 2:1 I made?
Someone stated if there ever was a way to choke off the exhaust, that is it. BUT the proof is in the numbers, it works....
http://xlforum.net/forums/s....php?t=1367025
The thing is the lollipops are adjustable, you rotate them to where you want them.
When installed parallel to the pipe outlet, the lowend is much increased, but top end suffers.
If installed perpendicular 90deg to outlet (zero blockage) the lowend suffers and topend is decent.
You need to find a happy medium, thats where the adjustability helps.
Check my stroker dyno thread, all info is there.
http://xlforum.net/forums/s....php?t=1265958
Old 28th June 2012
someone remembered,someone stating,that,and i,would too,if i,was the one with dyno,access.
