Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Introduce Yourself
Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 27th June 2012
75Ironheads 75Ironheads is offline
Other Motorcycle Model: Heritage Classic
Other Motorcycle Year: 1996
75Ironheads is an unknown quantity at this point
Default Hello, from Philly...
Hi, from Philly with my 75 Ironhead...
Great info. already found on here, thanks. I'm new to bikes, my bike was left to me by my brother and been sitting for few years. So I'm going to get it running and do everything myself so I can learn as much as possible.
Thanks in advance...
Old 27th June 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
Welcome to the forum from VA!
Old 27th June 2012
WinterWheel's Avatar
WinterWheel WinterWheel is offline
WinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud ofWinterWheel has much to be proud of
Welcome from Canada's Capital!
Enjoy the process. You'll get a lot of help here. Be sure to check out the Ironhead threads.
I don't want to simply be alive. I want to feel alive!
I prefer to ride the Stallion, not the Plow horse!
Old 27th June 2012
1iron1's Avatar
1iron1 1iron1 is offline
Sportster/Buell Model: iron883
1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light1iron1 is a glorious beacon of light
Hello from Central PA.
I'll be watching the roads, looking for you!
Why can't I have bacon every day?
"We are what we repeatedly do. Excellence, therefore, is not an act; rather, a habit." - Aristotle
Old 27th June 2012
shotgun46's Avatar
Welcome From Tennessee ! we would like to see pictures of your bike
Sportsters Rule ! :banana
Old 27th June 2012
oreocat1's Avatar
oreocat1 oreocat1 is offline
Sportster/Buell Year: 11
Other Motorcycle Model: Yamaha FZ-07
Other Motorcycle Year: 2016
oreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond repute
Welcome from mid Missouri
Old 27th June 2012
MaNickles's Avatar
MaNickles MaNickles is offline
Sportster/Buell Model: XL1200C 2005
MaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of lightMaNickles is a glorious beacon of light
Welcome and good luck getting her going again
Old 27th June 2012
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Welcome to the forum from sunny Italy!
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 27th June 2012
Old 27th June 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Welcome to the forum from SW Pennsylvania.
George
--Thomas Jefferson
