Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 27th June 2012
sevenyears of famine's Avatar
sevenyears of famine sevenyears of famine is offline
sevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to allsevenyears of famine is a name known to all
Default Tranny expedition - 1960 stroker
Due to 3rd gear slipping and discovering a few pieces of metal in the trans oil, I will be pulling out the transmission. I'll do my best to post good pictures so you guys can give educated input. Hopefully you can help me through this and it might help someone else down the road.
I wanted to state the fact that this motor has been bored and stroked, that way when we get into it, we might be able to determine other parts that have been beefed up or might need to be upon reassembly.
Dug into it a bit last night:
First I drained the transmission oil... again.
Removed "left footrest" & "rear brake foot lever"
3 screws then popped off the primary cover
Clutch cover. I just put this on a couple weeks ago and I used RTV gasket silicone when I put it back on because I couldn't find a reason not to. Well, now I know why not to, it was a bear to get off.
pressure plate & nuts, springs & cups
releasing disc
then removed all the friction & driven plates
chain adjuster deal
moving to the other side next
Old 27th June 2012
Vermonter's Avatar
Vermonter Vermonter is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: 80XS650/71CL175/7?gs550
Vermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of light
if your not having any problems with your cams no need to open the other side up. Remove your clutch basket to get to the transmission.
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." Thomas Jefferson
Old 27th June 2012
I was wondering this, but don't I need to take off the drive sprocket?
Old 27th June 2012
Vermonter's Avatar
oh ya but that is just the sprocket cover, not the cam cover. I just didn't want to see ya open up and drop a cam or something when you don't need to.
but you will have to remove the clutch basket, and primary drive as well.
Old 27th June 2012
good, cuz I already took it off.
Removed pipes, right foot peg, kicker & chain.
Manual says you might have to use an all purpose puller to get the sprocket off. So happens I have something like that and so happens I needed it.
had to pry this little guy off
order of clutch rods (as they were anyway)
now this can't be good, but it may not be all that bad? Seems these threads are just holding the sprocket cover on? What about that little dowel thingy, what's that do? It's barely in there, I'm guessing it just lines up the cover?
Old 27th June 2012
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
"now this can't be good, but it may not be all that bad? Seems these threads are just holding the sprocket cover on? What about that little dowel thingy, what's that do? It's barely in there, I'm guessing it just lines up the cover?"
AND it supports the cover as your body weight comes down on the kicker! I hate seeing this, damn early cases are like clay, I'd gunk the hell out of it and look alot deeper in the speedo drive area before your proceed throwing money at the bike... Good Luck
Cycle World Oct 1962:
Old 27th June 2012
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Quench plug at end of shift fork rod missing.
Gouging on kicker shaft and cover bolt hole and dowel damage. Sprocket too large... What's tooth count?
Think that's your issue, there.
I'm sure you noticed the case weld under upper portion of sprocket cover...
Old 27th June 2012
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
transmissions,dont slip,but clutch's do,especially,dry one's,when they get oil on them.it's possible that this is a,clutch issue. plate's do not appear to be oil saturated,but adjustment change,might be,necessary. hate to see you pull the trans.,for a,clutch issue.
Old 27th June 2012
you messin with me man?
http://xlforum.net/forums/s....php?t=1494612
yes you have transmission,damage. also it would be wise not to remove that plug again.it'a,steel,plug in an,aluminum case and it will strip out soon.drain the transmission by,removing the,primary cover.
i,think the damaged pieces,look like,gear dog material,rather than,gear teeth.
Old 28th June 2012
no,im' not.recognized your screen name,but not your,previous problem. i,thought this was your first post on this problem. my,mistake. please continue. [i,don't remember you mentioning that,dual throat carb in your original post,that i,would have,remembered.]
