0 LePera Kickflip
Last Post: icebob
0 What's your helmet?
Last Post: Grymy
0 what do you think of these plugs?
0 A Day in the Life...
0 2016 48 Hesitating
Last Post: XLXR
0 'Idiot Lights' plastic face
Last Post: Edster
0 Cartridge Conversion?
Last Post: XLXR
0 Flirting with death
0 Tried to buy a new helmet
Last Post: kap
0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Old 16th July 2012
Tater's Avatar
Tater Tater is offline
Sportster/Buell Model: 1200 C
Sportster/Buell Year: 09
Tater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to all
Default Exact Capacity of 4.5 gal. Tank...???
Since my low fuel light does not work properly, and I ride the boonies mostly I use my milage as a gas guage... I usually fill up near 150 mi. and it usually takes +/- 3.5 gal. ... I fill to the flat sheet metal ring in the neck & on the jiffy stand, is that what is considered a full tank...???
I was just wondering if the 4.5 gal. was on the money or like most other stuff is just sorta close to the actual capacity, and if my fill ups are propper for a full tank, as some times it gets scarey before a gas station is located...???
Any info would be appreciated...
Thanks, and have a good one...Tater...
Sportster Owner/Rider since age 72...lol... Rider since Simplex...???
09-xl1200 "C" Vivid Black, Cast 19" Frt. Wh., Moded Stage 1+, X14iEDs, 29k + mi...
MicroTach +, Higher wider H-bars, Mustach bar Mtd. Hwy. pegs...
Viking Shock Cutout Saddlebags, Mustang Seat, Rear Mt. Signal Lt. Kit, SuperBrace...
Old 16th July 2012
Baphomet's Avatar
Baphomet Baphomet is offline
Sportster/Buell Model: XL883L/1200 (Sold)
Sportster/Buell Year: 08
Other Motorcycle Model: FXDWG (wide glide)
Other Motorcycle Year: 2015
Baphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond repute
I believe the 4.5 gallons is what it would hold without a fuel pump inside the tank. I'm sure the pump takes up some of that volume, but I don't know how much of it. I guess one could fill the tank and then drain it in a container and get a precise measurement how much comes out. But you fill yours just like I do ... to the rim. I guess that's as full as it can get.
Old 16th July 2012
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
You should be happy that the same (or close) amount goes in the tank.
Run with that fact.
Many use the trip odometer and fill at designated miles gone.
I fill every 100. I know 120 area and expect the engine to sputter and need the reserve switch to be thrown.
100 miles is a good time to get off the bike and stretch my legs.
You don't want to be running the tank near empty.
The gas in the tank is the coolant for the fuel pump.
It's hard on the pump without coolant.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Old 16th July 2012
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
I take around the same amount at 150 miles. Most I have put in my 06 is 4.2 gallons. I almost always stop around 150 and normally take 3.5 - 3.8 gallons. However when I took 4.2 I had only traveled around 160. I had a very stiff headwind that day, so be aware of any high winds and plan accordingly.
John Wayne - "The Shootist"
Old 16th July 2012
aklim's Avatar
aklim aklim is offline
Sportster/Buell Model: 883 Superlow
aklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura about
I've heard that one many times but no one has really substantiated it. I don't think it generates that much heat that it could burn the fuel. I sure wouldn't want a heating iron in the fuel, would you? Also, as to the coolant part, the fuel running thru it probably does the job and if you run out of fuel, the pump stops since the motor quits so not sure where the problem is.
Old 16th July 2012
PiousDevil's Avatar
PiousDevil PiousDevil is offline
Sportster/Buell Model: 883->HP1250
PiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant future
Just curious, op, are you running the bike with the petcock "on" then switching to reserve when you sputter out? I use my odometer to time fill ups as well, but that reserve is always there waiting for me.
Always thinking 360°
Old 16th July 2012
04xl1200c's Avatar
04xl1200c 04xl1200c is offline
Bike Builder
Other Motorcycle Model: CB750k SOHC
Other Motorcycle Year: 1977
04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future
As a mechanic I can assure you that the fuel does Infact cool the fuel pump and the fuel pump is a Delphi unit its a pos all gm's come with the same pump and they fail often for the same reason... People run the tanks down to "e" a lot! So with that being said... I wouldn't push much beyond 150 if you putting 3.5 in that 1 gal left should be enough to cool the pump!
"pious devil" the bikes they are referring to don't have petcocks they are "efi" they only have a low fuel light like your car.
I love my Samson Powerflow III 2-1 Exhaust Check out the video's
Dyno Run:
[URL="http://youtu.be/q59aSkpxFbE"]http://youtu.be/q59aSkpxFbE[/URL]
After install:
[URL="http://youtu.be/f3vMKoFHw-8"]http://youtu.be/f3vMKoFHw-8[/URL]
Facebook XL Group:
[URL="http://www.facebook.com/groups/202086829894902/?ref=ts&fref=ts"]http://www.facebook.com/groups/202086829894902/?ref=ts&fref=ts[/URL]
Facebook TC88A Group:
[URL="https://www.facebook.com/groups/TC88A/"]https://www.facebook.com/groups/TC88A/[/URL]
[IMG]http://i1088.photobucket.com/albums/i334/cbsevenfiftyk/2-1%20exhaust/th_DSCN0231.jpg[/IMG]
Old 16th July 2012
rubyred rubyred is offline
an obsession handed down
rubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant future
Before my lift and SE air filter, I once ran it to 164 and had not turned it to reserve...but usually I'd fill up at 155.
Taxes are paid!
Old 16th July 2012
aklim's Avatar
I never had a car that ran above a quarter tank before filling. Unless I had to, every time I ran it, they would be at the "E" mark and then some before I filled. So doesn't the fuel running thru it cool it? If what you are saying is true, I should be changing pumps every couple of months. I would think the fuel running thru it constantly would be way more cooling than just the fuel sloshing around especially if there is a fuel tank baffle.
Old 16th July 2012
PiousDevil's Avatar
All this new fangled technology, how can an old man keep up?
