0 New member in MD
Last Post: ReddTigger
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 Help me with gas cap...
0 Sportster or Street Bob
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Cad Plating
Last Post: conv90
0 1968 XLCH Oil Leak
Last Post: 72 Ironhead XLH
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
0 Drive Chain Adjustment
Last Post: class of 82
Last Post: RKN
Old 16th July 2012
Tater's Avatar
Tater Tater is offline
Sportster/Buell Model: 1200 C
Sportster/Buell Year: 09
Tater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to all
Thanks folks, I would not run over 150 mi. anyway unless caught in a have to situation, I really like to have plenty of fuel...
Thanks and have a good one...Tater...
Sportster Owner/Rider since age 72...lol... Rider since Simplex...???
09-xl1200 "C" Vivid Black, Cast 19" Frt. Wh., Moded Stage 1+, X14iEDs, 29k + mi...
MicroTach +, Higher wider H-bars, Mustach bar Mtd. Hwy. pegs...
Viking Shock Cutout Saddlebags, Mustang Seat, Rear Mt. Signal Lt. Kit, SuperBrace...
Old 16th July 2012
aklim's Avatar
aklim aklim is offline
Sportster/Buell Model: 883 Superlow
aklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura aboutaklim has a spectacular aura about
I usually run it to about 180 or about 50 miles after the light comes on.
Old 16th July 2012
Tater's Avatar
That's about what I'm thinking I coud do (50 mi.) in a need to case, I usually seem to have a very slight bit over a gal. left when the light comes on, if 4.5 is correct...
Thanks all, and have a good one...Tater...
Old 16th July 2012
BKB's Avatar
BKB BKB is offline
Tater, my C will start to sputter at WFO after 180 miles. Actually pulled into station at 190 miles, still running & it took 4.2 gallons. Too close for me. I usually gas up at 150 to 160 these days.
Aklim, if you run it out of gas, the pump will continue to run untill you shut off the ignition, thereby burning the pump out. If you hit the kill switch when the bike stalls you'd be OK. I doubt it would set the residual gas in the tank on fire, but I don't care to test that theory.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
Old 16th July 2012
sco0842's Avatar
sco0842 sco0842 is offline
Sportster/Buell Model: XL1200L Sold
sco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura aboutsco0842 has a spectacular aura about
Well atleast I know it will hold atleast 4.2 gallons. The pump and expansion room has to take up some. I am imagining that they gave the total capacity without the pump and including the expansion. I wonder if the designer left out the words actual capacity in the manual so that we could have a discusion this long about it.
Old 17th July 2012
rubyred rubyred is offline
an obsession handed down
rubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant futurerubyred has a brilliant future
I've thinking about putting a 1 gallon jug of gas on the rear and seeing how long she'll go with the lift...
Oh, and Brian...I thought 164 was pushing it. Geez!
Taxes are paid!
Old 17th July 2012
aklim's Avatar
That doesn't make sense at all. I have run a few cars out and the pump never runs after the engine dies. I can hear the pump prime when the run switch is set on. I pulled the plugs and the pump stops with the engine so it cannot be still pumping.
I believe there is a pump relay that will only be set to run when the engine is running or it is being primed. Otherwise, if you run out of fuel and leave the ignition on, BOOM!!!
And yes, the wife left the bike in run mode one night. Battery was low the next day but no explosion.
Old 17th July 2012
sco0842's Avatar
GM only runs the pump while the engine is running. This is for accidents so that the pump is not putting fuel on the ground. Ford uses a switch in the passenger compartment that trips in a head on collision. I have not paid attention to the pump when stalled. I know the tilt kills it.
Old 17th July 2012
sco0842's Avatar
The wife is convinced that soon she will be following me with 4.5 gallons of gas in the truck soon.
Old 17th July 2012
aklim's Avatar
I stalled it but the pump was silent unlike when it primes.
