Last Post: roadsterboy
Last Post: Airbozo
Last Post: _Outlaw
Last Post: mor
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
Old 20th July 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
Did you rejet carbs?
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 20th July 2012
markncarj1's Avatar
markncarj1 markncarj1 is offline
Sportster/Buell Model: xl883/1200c
markncarj1 is on a distinguished roadmarkncarj1 is on a distinguished road
the sound happens after i excellerate pretty hard sometimes during the excelleration. but it stays at idle for about 10 seconds then it seems to stop but it will happen sporaticly at idle when the bike it hot like a jingling spring. only on the front cylinder. i increased the jet size one size up on the main only. this was after the conversion. I at first thought i had an exhaust leak. non of this happen right away after the conversion. it ran killer for atleast 500 or so miles then it started. Im wondering if there is a leak at the exhaust side of the head. it would explain the backfiring on decelleration now which didnt happen before. do the metal cometic gaskets need re torqing after so many miles when brand new?
Old 20th July 2012
markncarj1's Avatar
as an 883 i dynoed the bike and i was running a 45/180 and a shimmed nokk needle. i just bumped up the main to a 185 and that was it. turned out the adjustment screw to 2.75 turns out.
Old 20th July 2012
do0zman do0zman is offline
Sportster/Buell Model: Sportster 1200c
do0zman is an unknown quantity at this point
What do your plugs look like? Chocolate brown is "Ideal". All climates and bikes are different but i think 185 main and a 45 slow w/ 2.75 turn out should be good enough to not be lean but again check your plugs and see for yourself.
A ping on hard acceleration says its detonating. This is from what i know and personally gone thru.
Old 20th July 2012
markncarj1's Avatar
I had the rear head come loose within 100 miles already. I think your right and a compression leak will cause it to run badly too. again it is the front cylinder only. weird. i will run a compression check. the plugs arent new but the back one is a little fatter than the front. no black on the front.
Old 22nd July 2012
markncarj1's Avatar
ok not detonation. it is definately a valve possible tweaked but wont know for sure until i compression test it. i think the mid has been running lean and the lean condition messed up a valve
Old 25th July 2012
markncarj1's Avatar
http://www.youtube.com/watch?v=y9Na3...ature=youtu.be
here is the noise it is making. you can hear the valve at the end of the video
Old 26th July 2012
markncarj1's Avatar
Ok well i have a bad lifter. took out the front 2 and i couldnt push down on any of them but i noticed that one of them i could spray fluid through one side and it would come out the other side. and the good one i couldnt. seems the valve in one isnt closing and staying open. so now i need to find 1 lifter.
