0 Feeling in trouble.
Last Post: sdsbassist
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
7 Long Road Trip advice
Last Post: gravydog
Last Post: seanq2208
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
Old 21st July 2012
antsap's Avatar
antsap antsap is offline
Sportster/Buell Model: 71' XLCH
Sportster/Buell Year: 1971
Other Motorcycle Model: 1956 FLH
antsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura about
Default Thoughts on Lucas oil upper cyclinder lube in your ih?
So what do you guys think? Claims to be good at removing carbon deposits which I certainly have. Is it safe for our gals?
Old 21st July 2012
doodah man's Avatar
can't imagine it would hurt anything. i posted about my bike "dieseling" last summer and one of the comments was that it could related to excess carbon, and one way to get rid of the carbon was to remove the air cleaner and lightly (very lightly) spray a very fine mist of water into the carb, while revving it up enough to keep it from stalling out. any carbon that is in the combustion chamber will be dislodged and blown out the exhaust. it's been over a year ago now, i have yet to try this...
that old post is here, if you care to review it:
http://xlforum.net/forums/s....php?t=1117590
caution! do not stop on tracks.
Old 21st July 2012
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Lucas oil stabilizer is a 5 to one mix and heavy. So I can't imagine a half a pint in 2 qts will hurt, but never tried it. Since most old iron heads are almost total loss systems, not really but close, any difference is probably neglible.
Old 21st July 2012
antsap's Avatar
thanks doodah! I did my pushrods this week. I may re seal my exhaust and try the water technique this weekend.
Old 21st July 2012
randy3934's Avatar
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
Tried the water mist back in the 70s or 80s on a high mileage ironhead that needed top end redone, the trick is to make sure the engine is fully warm, at least 30 minutes of riding before misting the engine, upon disassembly of the engine it was noted the typical amount of carbon deposits were greatly reduced, it was also evident by the black sooty stripe on the shop floor from the sporty's drag pipes, it does work.
Old 21st July 2012
antsap's Avatar
I'm looking really forward to trying the water misting approach, thanks for the tip! Outside of that, is anybody actually running lubricant in their gas tank on a regular basis?
Old 21st July 2012
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
i,think it's a,good idea. would help to prevent wear on cast iron valve seat's,that haven't been,converted. ezmerf uses a,similar product i,believe.
Old 21st July 2012
IMO there is nothing special about the Lucas product. Another is the SeaFoam product. Remember Bardhol from days gone by? I am sure there are many others. Probably all the same except for the advertising.
I run the Seafoam thru my engine once a year, as part of my winter project.
Old 21st July 2012
tiderider's Avatar
tiderider tiderider is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 1976
tiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the roughtiderider is a jewel in the rough
Be careful if you do and follow a detailed regiment, seen a couple of issues by a buddy who got a little heavy on the H2O, started using oil, we pulled the head to find broken rings.
I like Lucas in my bt tranny, good stuff, never tried their gas treatment.
The Beast of Burden [URL="http://www.youtube.com/watch?v=d4WFOZYO2Xw"]69 XLCH[/URL]
Old 22nd July 2012
yes a,liquid can't be compressed.it causes hydro-lock. similar to when fuel floods the combustion chamber. i'm,not against that idea,but the water must be sprayed in,with,fine droplets. [mist]
