Last Post: Grumpy-Biker
0 Salutations y'all
Last Post: Alias Bob
0 no rear brake light
0 67 Sportster build
Last Post: ldurmon
Last Post: geoff
Last Post: goblin_dust
0 What's your helmet?
Last Post: lucky23
Last Post: cotton1
Old 21st July 2012
DWilliam's Avatar
DWilliam DWilliam is offline
DWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really niceDWilliam is just really nice
Mine used to fall and hang on the bottom hinge all the time. Then a month or so ago, it fell off somewhere in NH. It doesn't flop around anymore now
Old 21st July 2012
rocketmangb's Avatar
There are some up dated clips which help
My side covers are painted for a reason !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 21st July 2012
knew.start2010's Avatar
knew.start2010 knew.start2010 is offline
knew.start2010 is an unknown quantity at this point
Mine fit pretty good now. It used to come loose all the time. I just replaced the plastic clip and havent had a problem
Old 21st July 2012
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
ZIP TIE...........Bouncing down the highway tends to scratch the hell out of them.....
Old 21st July 2012
Phaedrus's Avatar
Phaedrus Phaedrus is offline
Originally Posted by SportyLou View Post
Ok thanks Gents, sorry about that Pete, probably could have searched for it before posting
no need to apologize, I just posted those to be helpful
Old 21st July 2012
morvenhouse's Avatar
morvenhouse morvenhouse is offline
morvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud of
I'm a zip tie guy now to, early 04 rubber mount and chrome battery cover with gravel rash, wish I had found out sooner.
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
Old 21st July 2012
Deimus Deimus is offline
Master Bike Builder
I also use a small zip tie but you don't need to fasten it. With the cover in place, drill a small hole through the front clip passing through the open slot of the cover. Cut your small zip tie to be about 1 1/2 inches long and stick it through the hole like a pin. The head of the zip tie needs to be larger than the hole you have drilled. Then to remove your cover all you do is pull your zip tie pin out first. Simple.
Old 22nd July 2012
nixl12 nixl12 is offline
nixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to allnixl12 is a name known to all
same as Deimus...found it on one of the threads
Old 22nd July 2012
threat357's Avatar
threat357 threat357 is offline
Sportster/Buell Model #2: 1200 CHOP PROJECT
Sportster/Buell Year #2: 1997
Other Motorcycle Model: 1200 CHOP PROJECT #2
Other Motorcycle Year: 1992
threat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to all
Originally Posted by sportsterdoc View Post
At least you have a bottom hook. When the rubbsters came out in 04, they were blowing off down the road.
The '04 has a bottom hook too. Just saying.
Old 22nd July 2012
SportyLou's Avatar
SportyLou SportyLou is offline
SportyLou has a spectacular aura aboutSportyLou has a spectacular aura aboutSportyLou has a spectacular aura aboutSportyLou has a spectacular aura aboutSportyLou has a spectacular aura aboutSportyLou has a spectacular aura aboutSportyLou has a spectacular aura aboutSportyLou has a spectacular aura aboutSportyLou has a spectacular aura about
It was indeed helpful, spent yesterday washing the bike and zip tied the battery cover up, unfortunately once I finished I realized during the process I had drank a beer or twelve so Ill have to test it out today instead
"Ride it like you stole it, well unless you stole than you should just hide"
