0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 22nd July 2012
moparerrnocar's Avatar
moparerrnocar moparerrnocar is offline
Sportster/Buell Model: 1250
Sportster/Buell Year: 94
moparerrnocar is an unknown quantity at this point
Default Mixture screw has no effect on RPM (pilot too big?)
If the mixture is fully seated and the bike still idles no differentially does this mean the pilot is too large?
My bike has no change in rpm in relation to the mixture screw (anywhere from seated, to 4 turns out). Idles set @ 900-1000. Currently it has 45 pilot but I think its too big.
Bike is a '94 883/1250, 883 heads w/ 1200 valves (10.3:1), SE AC, 1.75 drag pipes, SE .497 cams, dyna 2000 ignition and twin fire coil. The carb has a red yost needle in the #4 clip (w/o shim), yost tube, yost spring, and 180 main.
Old 22nd July 2012
sportsterdoc's Avatar
Other Motorcycle Model: Triumph Bonneville
I doubt that your pilot is too big.
My first thought is a vacuum leak.
How does it run?
Old 22nd July 2012
Deimus Deimus is offline
Master Bike Builder
I remember from some thread years ago where someone was having trouble trying to cure a too rich situation. It turned out that the diaphram in the petcock had a small leak and fuel was getting into the engine via the petcock vacuum line. I'm not suggesting you have this issue. I'm only making you aware of a possible source of fuel if you still run a petcock with a vacuum line.
Old 22nd July 2012
How does it run?
I've sprayed carb cleaner around the boot and manifold b4 but noticed no change. How would a vac leak allow the bike to idle w the mixture screw seated?
It runs, "ok", throttle blips and roll ons could be better. Its not as responsive as I think it should be. It also pings when passing on interstate if I dont down shift. You only hear it if you turn your head and put you ear near the tank, otherwise there's too much wind/exh noise. I dont have a tach but you grab a fist full of throttle @ 2,500 in first gear it rips your arms off and pulls the wheel of the ground about 2" when I grab 2nd. Runs great and pulls strong all the way to 6k. I've backed the timing off trying to get rid of the ping, but if I go any further I'll sacrifice torque. This was off topic, but I figured I should mention it.
Old 22nd July 2012
rocketmangb's Avatar
Might check the float level
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 22nd July 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Your engine set-up is similar enough to what I have on my 97. Tuner used a Dyno-Jet Carb Kit. Clip is on the 3rd knotch, 45 pilot, 180 main and 3.5 turns out on the idle mixture.
Your 45 pilot should be fine. I'd look for fuel getting into the mix from somewhere else.
[SIZE="2"][/SIZE]Support the forum because the :xlrocks
George
[COLOR="Blue"][B]"Peace is that brief glorious moment in history when everybody stands around reloading . "
--Thomas Jefferson[/B][/COLOR]
Old 23rd July 2012
The petcock diaphragm is a possibility, as well as the enrichener circuit.
Old 23rd July 2012
...I've backed the timing off trying to get rid of the ping...
Have you checked your VOES?
Old 24th July 2012
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Model: Ducati
Other Motorcycle Year: 1974
oldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant futureoldboy has a brilliant future
I had the same with my '06 1200. Finally read a post by another member (don't remember who) who changed out their accelerator pump diaphram and that took care of the issue.
I changed mine, the old one didn't have any tears or holes. It was discolored and had some corrosion on the top side. After changing it, my mixture adjustment finally works.
Don't know if your bike, being older, has an accelerator pump, just my .02.
2006 1200c: Home Made a/c, Cycle Shack Slipons, Daytona TC88A w/JesterVII map (thank you, Rico), Street Trackers
Old 24th July 2012
No diaphragm, but enrichener might be a possibility. My voes works, but not sure where it should be set.
Really, hmm, you know that just might be it. I too checked it for cracks/holes and found nothing. I guess its worth a try, sure cant hurt. Thanks
