Last Post: kaveebee
0 Help me with gas cap...
Last Post: pucketprutectah
0 1968 XLCH Oil Leak
0 primary chain temp.
0 Sportster or Street Bob
0 Newbie CV rebuild
Last Post: Matt Black
0 Oil??
0 1977 xlch starter issues
Last Post: Yellowstone Kelly
0 no rear brake light
Last Post: SKID LID
0 THE Trainspotting Thread
Last Post: gravydog
Old 22nd July 2012
Monstar Monstar is offline
Sportster/Buell Model: xl
Monstar is an unknown quantity at this point
Default Chain conversion
I just went with a belt to chain conversion. My question is, how do you guys shim out the front sprocket? Do you use a big ass washer? It needs to come out about an 1/8 to 3/16.
Old 22nd July 2012
02883r's Avatar
02883r 02883r is offline
Sportster/Buell Model: 883r
02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all
I used the zippers conversion. It actually came with the correct spacer..... I would recommend getting that. I would imagine you could get it from nrhs; that was where i got my conversion? Are you using dished or flat sprockets?
Old 22nd July 2012
I'm. Using zippers.
Old 30th July 2012
aablacknight's Avatar
aablacknight aablacknight is offline
Sportster/Buell Year: 60
aablacknight is on a distinguished roadaablacknight is on a distinguished roadaablacknight is on a distinguished roadaablacknight is on a distinguished road
You can order offset sprockets from the Drag Specialties catalouge. Most shops can get them for you
Old 30th July 2012
Question: Does your front and rear sprocket line up now if you have it installed like normal? if so then you do not need an offset sprocket. All you need is a different spacer under the front sprocket. You probably have a .600 wide one now? You should need a .800 one. I sell them for $35.
Or do you need the sprocket to be out farther to line up with the rear sprocket?
