Last Post: leon bee
5 Transmission HELP!
0 ALIEN Themed 1250
Last Post: Shai`tan
Last Post: MatHormell
Last Post: ezmerf
0 ParrotHead's Mods For My "New" Sporty
0 Ei
0 Sportster or Street Bob
Last Post: Bone
Last Post: hexnut
Last Post: conv90
Old 30th July 2012
oupa's Avatar
oupa oupa is offline
Other Motorcycle Model: YES
oupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond reputeoupa has a reputation beyond repute
Brand new bike? BOTH bolts let go? This is something they ought to be right on top of! This is a real safety issue - if it were to happen at speed.
It's unlikely two bolts would break for no reason.
If it's an isolated issue, it's likely due to someone over torquing the bolts, which probably means there are other bolts on it under the same stress, that should be checked and corrected.
If not an over-torque problem it would mean bad bolts, which would spread the problem over more bikes built in that lot.
The factory SHOULD want to rule out and or correct any of these scenarios ASAP. Either of the two latter ones could possibly result in a recall and they don't want that. Best case scenario though is for them to do it before an outside agency tells them to or publicizes a problem. Remember Toyota's market share plummet because some dorks didn't have the presence of mind to pull their floor mat out from under the gas peddle? Instead the media suggested there was a deadly defect. No company wants to go through that!
If the dealer stonewalls you, go higher and the sooner the better and make sure you do two things. Tell the factory folks every detail of your dealership experience and then never forget how these A-holes treated you when you need future service!!!
Old 30th July 2012
Jay Mack Jay Mack is offline
Sportster/Buell Year: 2012
Jay Mack is an unknown quantity at this point
Hey guys, thanks for getting back to me.
I am located in Sydney, Australia. There are only a few hd dealers here, this being the biggest. Are they are well known for poor service .
They have no proof of the bolts being touched by a outside source. I believe they are basing their conclusion on 1) perhaps this has Infact never happened before?
And 2) they have looked at the minor mods I have done myself and think this is a 'DIY' guy and he has had it apart.
I have been sure to document every step of the process, and have a lengthy list of wrong doings by them as far as this matter is concerned.
I am at work atm but once I get home I'll attempt to get some pics up.
Thanks again, you have given me some great stuff to work with.
Old 30th July 2012
Billyj7175's Avatar
Billyj7175 Billyj7175 is offline
Sportster/Buell Model: Forty Eight
Other Motorcycle Model: Street Bob
Other Motorcycle Year: 2009
Billyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant futureBillyj7175 has a brilliant future
I'm assuming the transmission seal they replaced was the drive pulley shaft seal? The reason I ask, is did they remove/reinstall the RH forward control during the seal replacement?...I don't have my TSM in front of me, but I'll check it later to see.
If so...THEY overtorqued it...
12' Forty-Eight (SOLD), 09' Streetbob, 17' BMW R1200GSA
Old 30th July 2012
@Billyj7175 I believe so,that's what they told me. And that a seal and o-ring needed to be replaced. Thanks
Old 30th July 2012
@oupa thanks for your imput. I will be sure to use it .
On the day of purchase both me and a mate purchased bikes at the same time, just under $48,000 was spent between us. Some good service is much to ask.
When I made the switch from sports bikes to a Harley I knew they can be problematic. But to have these issues prior to its first service is upsetting to say the least.
Old 30th July 2012
ParrotHead's Avatar
ParrotHead ParrotHead is online now
I am the great Cornholio!
Other Motorcycle Year: 1974
Just curious if the foot controls are installed at the factory or as part of the dealer prep.
Also, I wonder if when they worked on the bike if they used the foot controls as a convenient point to tie the bike down on the lift.
I have heard of similar issues happening. A friend of mine went to pick up his wife at work on his Ultra and when he went to fold down the rear floorboard it came off in his hand because the bolt sheared off. Since we were 70 miles from home he took it to a different dealer and they fixed it. Not sure if they submitted a warranty claim or sent the bill to the dealer who works on his bike.
John Wayne - "The Shootist"
Old 30th July 2012
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Harley-Davidson Customer Service
3700 W. Juneau Avenue
Milwaukee, WI 53208
(414) 343-4056.
Old 30th July 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
I really hate to say it, but it sure seems like us sportster buyers don't always get the same service the big twin buyers do.
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 30th July 2012
Speedfreak's Avatar
Speedfreak Speedfreak is offline
Other Motorcycle Model: Ducati 749
Speedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really niceSpeedfreak is just really nice
No we usually aren't the guys dropping off our bikes with a credit card wanting fringe installed on the hand grips and shit lol so we get piss poor service
Old 30th July 2012
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Milwaukee, WI 53208
(414) 343-4056.
also @ 1-800-258-2464
